      10-08-2020, 03:19 PM   #1
drummr8
6MT FTMFW
Drives: 11 E90 335xi E91 6MT 12 X5 35i
Transfer Case/Transmission Mount Bushing Tool?
Does anyone know a good source for the tool used to remove the transmission/TC bushing? I found some tools on eBay, but they're all like 250 bucks.
Does anyone rent this tool? If not, I may buy it and rent it out to forum members if people are interested... My bushing was totally gone - it separated from itself! Found it while doing the TC fluid and Trans fluid. Now I'm stuck til I get that tool.
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete
      10-08-2020, 10:13 PM   #2
drummr8
6MT FTMFW
In case anyone comes across this problem, or decides to replace their transfer case mount, I was able to easily remove it using my subframe bushings tool from the e46. I rent it out on e46fanatics, find me on there if you need it. I'll post some pictures later
      10-18-2020, 10:12 PM   #3
drummr8
6MT FTMFW
https://photos.app.goo.gl/V57rGSXCDQDMTpgy9
Pictures of the tool I used, as well as how I used it are in that link. The new one slid right in by hand with a little bit of soap on it.
      10-20-2020, 03:21 PM   #4
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
Thanks for that, I had mine done at the dealer, next time I know what to do
