      07-19-2010, 01:14 AM   #1
Chooky
Australia
Drives: 2015 i3 Rex
Clock Message
Hi
Every couple of days i have to keep resetting
the time. Anyone else had the same prob?
Cheers
Chooky
      07-19-2010, 09:47 AM   #2
geneatals
Ninja
geneatals's Avatar
Drives: 2019 530e
might be a bad battery...my e60 was 2 yrs old, had that warning happen frequently over a 2 month span..then I finally had a high battery discharge warning...took my car in for service...took a few days to diagnose, but they finally changed the battery...no issue..
what the main concern should be s what's causing your battery to drain if it is that..could be a module not shutting down and not allowing your BMW to fully go into sleep mode....
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i
      07-19-2010, 12:40 PM   #3
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
+1
having to reset the clock continuously is a sign of a battery/power problem.
      07-20-2010, 09:13 PM   #4
archwerks
Drives: x6 3.5i VR
Check battery
Originally Posted by Chooky View Post
Hi
Cheers
Chooky
De Rigeur of power issues:
Do an advance search for info & make sure service tech. check the factory installed battery (part number) being correct b 4 doing anything else. See Car & Driver longterm test on their x6 5.0i
Good luck.
It may have come fr. the factory but .....
service will say u r not driving it enuf if it's not ur daily driver.
