      12-22-2009, 12:21 PM   #1
MeEmZ
Doctor in the making
MeEmZ's Avatar
Saudi Arabia
46
Drives: 08 X6 35i
idrive screen backlight problem
ok so this has happened a couple times before but a simple reset (two eject buttons + on/off button) got things back to normal. guess it's not the same this time.
The screen is functioning and everything is running it's just that the backlight is not on, it appears to be dim and sort of impossible to use unless you already know where everything is by heart.
Anyone has any idea what might be the problem ?? or has anyone had the same problem before ??
thnx
08 X6 35i
09 X5 3.0is //M
      12-22-2009, 12:56 PM   #2
bbmw
bbmw's Avatar
Belgium
Drives: Bmw X6 35d 2010
maybe check the scroll wheel for setting the instrument lightning brightness (to the left of the light switch). Or check settings - controldisplay - brightness on idrive... ?
      12-22-2009, 01:02 PM   #3
losmanos
losmanos's Avatar
Drives: 2010 BMW X6 3.0d
I had this problem with my 2008 X5 and after 2 dealers looked at it, it turned out to be a faulty screen and was replaced under warranty.
2010 BMW X6 3.0d
2009 BMW 320d Msport
      12-22-2009, 02:24 PM   #4
MeEmZ
MeEmZ's Avatar
Saudi Arabia
46
Drives: 08 X6 35i
checked that and it's on max brightness but still no light
i had it looked at a few days ago by a tech at the dealer during lunch break and he wasn't sure what the problem really was but he said that if they had a diagnostic test and the screen turned out to be faulty then they will have to change it under warranty and then they will reprogram the car
should i really be mad or happy that am gonna have a new software+screen ??
08 X6 35i
09 X5 3.0is //M
      12-22-2009, 03:40 PM   #5
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
thnx
I had the same issue. It turns out the battery needed to be charged up. I listen to music with the engine off at tail gate parties for tooo long.
If you battery is weak from minmal driving, or excessive accessory use with the engine off, all kinds of wierdness will show up from blank iDrive screens, to funky computer/audio operatios, etc.
If the dealer replaces the iDrive screen, chances are they mis diagnosed the issue. For if it were the screen, an iDrive reset would not correct the issue.
2011 535i
2008 VW GTI
      12-22-2009, 03:59 PM   #6
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
Battery issue is getting old.
MeEmZ (two eject buttons + on/off button) could you elaborate , where are the two eject buttons (I only use ipod,not cd) ? how do you turn it off ?
      12-22-2009, 04:41 PM   #7
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Press the in-dash DVD eject button along with the in-dash CD eject button along with the volume knob altogether for a few seconds. This is equivalent to a PC's CNTRL-ALT-DEL.
2011 535i
2008 VW GTI
      12-22-2009, 06:23 PM   #8
dmlgc
dmlgc's Avatar
ah a BMW three finger salute how appropriate
Thanks Chuck
      12-23-2009, 02:43 AM   #9
bbmw
bbmw's Avatar
Belgium
just curious, how do you reset the new idrive (with harddisk) as there is no second cd/dvd eject button??
      12-26-2009, 02:07 PM   #10
MeEmZ
MeEmZ's Avatar
Saudi Arabia
46
Drives: 08 X6 35i
ok new update .. after almost a week with the screen backlight not functioning, the light suddenly came back to life today while driving
the question is: should i follow up with the dealer to check what the problem is/was or should i just ignore and be happy that all is ok now ??
08 X6 35i
09 X5 3.0is //M
      02-01-2010, 09:51 PM   #11
JIMX681
JIMX681's Avatar
120
Drives: 2022 X5M Comp
I am having the same exact issue. My screen did the same thing. It started working again and lasted for a week and it went dim again. Does anyone think it could be the cold?
      02-02-2010, 09:25 AM   #12
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
Mine still has the issue every few months. I have to do the reset thing.
I don't think it is a cold issue. It is more likely a poorly designed iDrive system.
I don't think software resets and temp are related. Clearly a software bug.
2011 535i
2008 VW GTI
      11-16-2010, 07:15 PM   #13
Fserve55
Drives: 2008 BMW X6 50i xDrive
2008 X6 iDrive Black Screen Problem
I just got a preowned x6. Have had less than 3 weeks and already experienced the "black screen" on start up randomly 3 times... anyone who had that problem ever get it completely fixed?
I'm taking mine in for service this Thursday, 11/18 but they dealer already told me they'll run tests and if it comes back "clean" there's nothing they can do...?
Please help. This is my first beamer and I love my x6 but this is ridiculous as you all already know. I was an Infiniti guy for years and fell in love with the x6 in 2008 when I first saw it. Finally got it and I hope I don't regret it.
Thanks in advance, Eric in MD.
      11-16-2010, 07:18 PM   #14
Fserve55
did you ever figure yours out? get yours fixed? i noticed you're in baltimore also... which dealer have you tried to have help?
thx. Eric in baltimore area.
      12-23-2014, 08:12 PM   #15
dirtysti05
Drives: 08 bmw x5 sport
Last year my 08 x5 did this a few times when the cold weather started. it seemed on really cold days it did this. but i would just turn the car back off and on and it would work again. well this year it doesn't seem to want to come back on. same time of year the cold came and now it doesn't work again. is it cold related or just coincidence i don't know but it seems a lot of the electronics in the car seem to act slower in the cold. Has anyone come across a fix for this yet. Is it just some led's that need to be replaced or is it software?
