      11-24-2014, 09:15 PM   #1
bradysdad
bradysdad's Avatar
Drives: 2015 M4, 2020 M340ix
2013 Full LED Lights Issues
Purchased my 2013 X6 a couple of weeks ago, certified. Has the full LED headlight option. Had a previous service issue related to the lights which was repaired prior to my purchase.
Today I was driving and received a warning that my left High Beam had a fault. Sure enough, when I turned on the high beams, only the right side lit up.
Ran some errands, started and stopped the car several times and still had the error pop up. The last time I turned the car off and back on, the error went away and the left high beam started working again.
I guess the good news is that the light itself is probably OK, but something in the control circuitry is intermittent. Either way, warranty will cover it but I was reaching out to see if overall there have been a lot of issues with the LED headlights.
Thanks in advance...
      11-26-2014, 09:43 PM   #2
Southernbelle
Southernbelle's Avatar
Drives: 2013 X6 35i
Had the same issue with my LED lights. One of the fans that cool the LED bulbs had burnt out. It was covered under warranty.
