The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Thread Jacked delete
      10-26-2014, 11:44 AM   #1
essex_lad
Drives: E92 Msport N53 Stage 2
Thumbs down Thread Jacked delete
      10-26-2014, 01:01 PM   #2
pj.rodriguez
pj.rodriguez's Avatar
Drives: Alpine White 128i Cabrio
I did the same on my 128i
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
      10-26-2014, 02:50 PM   #3
essex_lad
Nice are you happy with the upgrade?
      10-26-2014, 03:46 PM   #4
Ph0zenstone
Ph0zenstone's Avatar
325
Drives: 2018 530e X-Drive
Nice upgrade...how are you "pushing as much bhp as a standard 335"?
      10-26-2014, 03:55 PM   #5
andrey_gta
andrey_gta's Avatar
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
Originally Posted by essex_lad View Post
I have only done the fronts for now but I will get round to the rear soon.
What is your plan for the rear? What caliper and what rotor?
How will you solve the rear hand rake issue of a large rotor form the 335i?
Will you use custom made hand brake shoes?
For his power, im sure hes running DISA & Tune getting nice 265+ #'s
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      10-26-2014, 06:22 PM   #6
essex_lad
Well that is the reason I havnt attempted the rear yet lol. I may use the rear hubs from a 335 as they are fairly cheap from breakers and they will most likely come with callipers etc. It may just be a matter of changing the shoes but I'll look more into it closer the time.
I have fitted the 3 stage manifold from 330I and loaded the mosselmon tune onto the ecu then I have verious other mods with a fine tune remap on top giving me 286bhp at the flywheel. If I was to compare power to weight ratio with a 335I I might just be on par.
      10-26-2014, 08:36 PM   #7
e92proper
Drives: 2011 e92 335 / 2013 X3
Lol^ no
      10-27-2014, 01:51 AM   #8
essex_lad
Why no explain how? I have no turbo lag no wieght of turbos, no weight of intercooler, no weight of oil cooler, lieghter gearbox, less intake componants, full exhaust system is lighter and other little things that all add up. so I'm only 14bhp down on a stock 335i so it's not far off at all. I'm sorry but you would need to enlighten me a bit on your immature response to my post.
      10-28-2014, 02:27 PM   #9
tke344
Drives: f15 X5 50i
I think you're forgetting that the 335i is significantly underrated from the factory, they typically put down close to 300WHP stock. Its ricer math until you get on a dyno.
      10-28-2014, 03:09 PM   #10
essex_lad
Either way its not far off like I said. never said it was faster.
      10-28-2014, 03:35 PM   #11
gaza01
gaza01's Avatar
Drives: E92 335i
Nice brake mod. Power mods sound good as well. Fair play for exploring the potential of the 325
Did you do the brake lines yourself? How easy is the bleeding?
      10-28-2014, 06:28 PM   #12
essex_lad
Thanks Gaza and yes I did. Bleeding was very easy to be honest, the only hard part was listening to me girlfriend keep going on about how her leg hurt from pumping the pedal lol.
      10-28-2014, 06:29 PM   #13
Cloud9blue
Cloud9blue's Avatar
Drives: around the potholes
top hp means nothing... it is all about the power delivery and hp/tq curve... does your N52 makes +300 ft-lb of torque at 3000rpms? Doubt it
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins
19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization
      10-28-2014, 06:44 PM   #14
essex_lad
A stock 335I doesn't make 300+ torque at 3000rpm but my n53 does make around 260 at 3000rpm
Not my print out as I don't have a scanner but from mosselmon who supplied me with my first tune before I had it fine tuned.
Stock 335I:
      10-28-2014, 08:38 PM   #15
Ph0zenstone
325
A stock 335I doesn't make 300+ torque at 3000rpm but my n53 330 does make 341 at 3000rpm
No offense but That dyno is probably seriously flawed. With the mods you have (which a hudred other people on this forum have), there's no way you're anywhere close to 280+ hp. That dyno shows almost a 50hp increase from the tune which I highly doubt is accurate
      10-28-2014, 11:13 PM   #16
drmdvl
drmdvl's Avatar
Drives: 2015 X5 50i, 2015 Macan Turbo
http://s566.photobucket.com/user/coope046a/media/bmw/bmw_N53_325i_performance_package_zpskqcrlvbr.jpg.h tml][IMG]http://i566.photobucket.com/albums/s...pskqcrlvbr.jpg[/IMG][/URL]
Either way... Nice increase and I'm
Sure it's fun to drive!
Btw - in the legend of that dyno, the torque is measured in Nm which is about 250 ftlb. Oh, and good job on the brake conversion.
2013 E92 335xi 6MT MSport
JB4, PS2, Pure Inlet, N20 TMAP, ETS FMIC, Drop in filter, 4" AR DP, Fuel-it Stage 2, ER CP, GFB DV+, E50
      10-29-2014, 12:51 AM   #17
essex_lad
It isn't just a remap on a 325i I have changed the inlet manifold, air intake and full exhaust system plus lightened flywheel to help drive train loss. After changing the manifold and putting the 330I program on the ecu it Is very achievable. To be fair mosselmons dyno sheet isn't all that different to my one also mosselmon are a very professional company and take what they do very seriously like most German companies so they wouldn't have "flawed" dyno readings.
      10-29-2014, 01:07 PM   #18
dbworld4k
Drives: '12 M3
2002 BMW M5  [10.00]
2009 BMW 335i  [10.00]
Get your car dyno'd at a Dyno Jet. Until then, all these claims are baseless and pointless.
      10-29-2014, 02:13 PM   #19
essex_lad
I have and I will upload them soon once I get the chance of using a scanner.
Tags
335i, black, brake, conversion, diamond
