      05-11-2013, 08:00 PM   #1
MidnightBlue35i
Drives: Bmw X6 35i M Perf
What is the mileage of your X6?
Can you guys share how many miles are on the clock of your X6 and what, if any major repairs you've done.
I plan to keep my X6 for a long time and helps to know what I am getting into.
      05-11-2013, 09:30 PM   #2
mikikuki7
mikikuki7's Avatar
Drives: Searching for X6M or M8
10k nothing wrong but rattles )
      05-12-2013, 11:37 AM   #3
crunchingnumbers
crunchingnumbers's Avatar
16
Drives: 2022 X6M, 2018 RRS
2012 x6 5.0 @ 36K and only a fuel pressure pump failed.I have noticed the odd engine stoppage usually just after start and turning the steering wheel - bizarre but also happened on a X5 I had due to a tighter than warranted wiring harness.
Other than that - OEM performance plastic body parts don't stay in place. Very poorly designed clips.
      05-13-2013, 04:01 PM   #4
wd
Drives: X6M
2011 X6 M at over 82.000 miles.
Tires replaced on average every 25 000 miles (currently fourth set).
Spark plugs every 36.000. Replacing spark plugs makes difference in power output.
Oil change every 15.000. I am adding about 1.5 quarts of oil between oil changes.
Only two minor problems so far:
at 29.000 fuel tank leakage diagnostic module replaced
at 51.000 clamps on turbo charger pipes due to low boost pressure replaced
No trim rattles. Drives great
      05-14-2013, 12:53 AM   #5
Jess///M
Drives: 2016 X6M
Wow -- that's pretty impressive performance and reliability over all those miles. I have about 23K and doing fine. Had one issue that the dealer fixed right away at 21K (vacuum problem in engine), but it's been fault-free and fun-filled otherwise.
      05-14-2013, 08:37 AM   #6
snoopstar
Drives: X6 5.0 X-Drive
64,000KM on mine, only had it a few months. Just started having a problem of the right rear corner dropping down sometimes when parked. Comes back up level as soon as it's driven. Yesterday, both rear corners dropped down low but it seems intermittent.
I presume its some kind of self levelling fault. Off to google I go.
      05-14-2013, 11:21 AM   #7
csherida155
Drives: BMW X6 2013
2013 X6 5.0i with 6330 miles and I have not had any problems at all.
      05-14-2013, 04:02 PM   #8
MidnightBlue35i
Wow thats really impressive. Made my day!!!
      01-07-2014, 10:03 AM   #9
snoopstar
To follow up on my post, problem was a faulty air suspension strut. Replaced both sides and all good.
      01-07-2014, 12:58 PM   #10
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
58k 09 X6 5.0 V8 - transmission required replacement
95k 11 X6M V8 - transmission requires replacement
Watch our for this problem. It will cost you over $10k to get it replaced at a BMW dealership. Seems like it can go at any time ...
      01-12-2014, 03:03 AM   #11
reihani
Drives: 2011 X5M
unreal. definitely making me think twice about extended warranty.
      04-04-2014, 12:42 AM   #12
Polow
Drives: 2011 BMW x6 5.0
56,000 just about...
      04-04-2014, 02:07 AM   #13
6lacksheep
6lacksheep's Avatar
Drives: 2016 BMW X6M
My 2012 35i just hit 55000km today
      04-04-2014, 07:23 AM   #14
ddk632
Chief Senior Executive Managing VP of Orange Sales
ddk632's Avatar
Drives: 17 BMW F87 M2 6MT MG HBDGR !
2013 X6M
21.5k miles
Only issues have been clicking noise from front suspension and mpg meter not working.
Control arm replaced and suspension issue fixed.
Mpg meter haven't dealt with yet.
My car thinks she gets 40mpg (was 99.9mpg for a while).
It's actually kind of funny.
Drinks a quart of oil around every 5-7k miles.
      01-03-2016, 06:53 AM   #15
peter2772000
Drives: 2012 X6 35i Sport
2012 X6 35i with 41k miles to date. No issues to report, but the warranty's expiring and I don't want to spend the $6k for an extended warranty. Car is from Canada and we imported it into the states for use when we come down to Florida (approx. 100 days/year). We usually rack up about 5000 miles per year.
I hope my choice to not buy the warranty doesn't bite me in the ass, but it's kinda hard to justify $6k US for something we barely use...
      01-11-2016, 06:11 AM   #16
Tailwinds
Drives: X6m
2012 X6M 50K
Plastic breather hose cracked. $20 part but replaced under warranty. That's it other than oil and tire changes! I drive it pretty hard. Maybe I should do the plugs.
      01-13-2016, 09:48 AM   #17
Kerrazy
Drives: X6M
84 000kms with a tune
-Change my oil every 12500 kms,
-Had injectors and spark plugs changed due to lugging
-replaced cracked breather tubes for turbos
-stereo amplifier replaced due to lost all sound
-Air conditioner condenser changed due to excessive noise
-Because of above glove box replaced
-Rear main seal on tranny replaced due to leak
Aside from above which was all warranty it has been an awesome ride, still love it, and love launching away from fast cars lol
      01-18-2016, 05:07 PM   #18
str8line
Drives: M4, X6, X5, X1, i3, X6M, 911
'14 X6M, 12K miles
Just an oil change at 10K, no problems at all.
      02-09-2016, 02:38 PM   #19
akraptor
akraptor's Avatar
Romania
45
Drives: 35 D
'09 X6 35D 83,263 miles. Timing chain broke last thursday with a big thud, while driving at 40 MPH. No other changes since purchase, beside some gaskets and O rings. Transmission errors in the past year and particle filter clogged. Dealer asked 12,500 USD for a new engine.
      02-11-2016, 12:05 PM   #20
hiep92657
Drives: 14' 550i & 16' X5M
2010 X6M Space Grey
30,548 miles
      02-29-2016, 10:10 PM   #21
TeKkMaN
TeKkMaN's Avatar
Drives: 2013 BMW X6M
2013 X6M - Alpine White
Bought with 22,500 miles in 7/2015 and now has 23,800. No issues to report since purchased however I've only put 1300 miles on the car due to being away on business most of the time.
