Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 19" v710's. 235/35/19 fronts and 255/30/19 rear
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      09-28-2014, 08:01 AM   #1
tlester
Drives: 2007 328i Sport, Crimson Red
2007 328i Sport  [0.00]
I just bought this wheel/tire configuration for my e46 330i a couple of months ago. Yesterday I decided to rejoin the ranks of e90 owners (I also had a 328i e90 in the past) with a 2010 e90 335i. So, naturally... after spending nearly $2k on new wheels and tires I'm thinking.... will they fit on the new e90.
So... what do you guys think? will this fit?
The e46 is getting a new transmission right now so I can't just simply "swap them and try". Is anyone running this tire/wheel profile on an e90?
The offset is:
19x8.5ET35 front and a 19x9.5ET45 rear.
-Tom
      09-28-2014, 09:36 AM   #2
bmw325i
Drives: 2006 BMW 325i
They'll fit but you'll probably be looking for spacers after you install them.
      09-28-2014, 10:31 AM   #3
tlester
Why spacers?
      09-28-2014, 10:37 AM   #4
bmw325i
You don't need them but it will look alot better with spacers.
      09-28-2014, 10:43 AM   #5
tlester
Are they going to be too tucked in? I just looked them up and realized that the offset for the set designed for e90's is a bit different.
      09-28-2014, 11:12 AM   #6
bmw325i
That is basically the bolt on fitment the vendors will recommend for an lci e90 usually with a 265/30/19 rear tire. The offsets are somewhat conservative but you can decide what you want to do after installing them.
Tags
335i, e90, v710, vmd, wheels
