      01-17-2015, 12:37 AM   #1
jaylouie
Drives: 2007 e92 335i
e70 electro-mechanical parking brake failure
Hi all,
I have a 2011 e70 3.5 diesel. It is out of warranty
it currently has a parking brake error that i found. I used a bavarian technic cable to find the fault.
it is fault 6031 mech manual moved and 6034 mech motion timeout.
Does anyone have a clue on what is wrong?
      03-02-2015, 05:48 PM   #2
jaylouie
I took time to take out the whole parking brake module in the back of the x5 and found a broken Bowden cable. If anyone else has these fault codes, it's probably a damaged cable or sensor.
      03-03-2015, 11:12 AM   #3
007_e350
007_e350's Avatar
Drives: 335i 2008 MHD'd / x5d E70
Nice Find Op!! can you put a DIY together, could be a sticky
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
