      03-21-2018, 05:58 PM   #1
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
F90 M5 has no MAF, E70 X5M has no MAF
What's causing me to bring this us is that you can see there's a crossover pipe between the two intercoolers. Whether he's right or not I can't be sure, but RK on Instagram said it's to equalize boost between the two turbos since it's now MAFless vs before where the F10 had dual MAFs. My question is...would this be beneficial to us? Just a though.
https://f90.bimmerpost.com/forums/sh...php?t=1414257#
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      03-24-2018, 10:22 AM   #2
godmans
Drives: 135i / 335i / X6M
I have the same thoughts as you, would love to see some brave souls with aftermarket charge pipe fab a cross pipe
      03-24-2018, 11:28 PM   #3
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
It'll just be using dual MAP sensors instead of MAF.
Equalising the pressure output of the individual turbos would nett negligible gain, and would only serve to offer minor redundancy for a failing turbo.
Unsure how the individual wastegates would be controlled, given the MAPs would be seeing the same load in this setup.
VMAX 0-1000M ▒ ▒ 230@22.619 > 232@22.489
      03-27-2018, 05:14 PM   #4
m5james
m5james's Avatar
Our charge pipes include the recirc valves while the N63, N63TU and S63TU put them elsewhere. Unfortunately no ones makes aftermarket charge pipes for us.
      03-27-2018, 05:15 PM   #5
m5james
m5james's Avatar
Just curious since they must have done it for a reason.
