      06-19-2023, 11:44 PM   #1
svho
Drives: X5
Rear differential oil change
Guys,
Looking to change the fluid this coming week. Can someone confirm the rear plug/drain is this part # 33117525064?
From my research, looks like I need the following (2009 X5 X drive, 3.0):
Red Line 75W90 High Performance Gear oil (2 quarts).
33 NM torque
      06-20-2023, 11:13 AM   #2
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
You'll only need about 1L. The fill from new is 1.2L and since we don't have drain plugs you'll have to extract it meaning you're not going to get it all out. Up to you though whether you want a 2nd bottle or not.
60Nm is the proper torque for the E70 rear diff plug.
      06-22-2023, 04:07 PM   #3
Dekero
Drives: 2013 BMW X5 35I
Probably a late reply... But there is no need to replace the fill plug... I've changed my diff fluid 4 times since purchasing the truck 250k miles ago, just did it the 4th time this past weekend...
Highly recommend an Air driven Vacuum extractor to help drain the fluid completely... Harbor freight sells a nice one by Polk... Works great on the transfer case as well.
      06-23-2023, 03:09 AM   #4
Cnoro
Cnoro's Avatar
Albania
14
Drives: Bmw e70 4.0d xdrive
Originally Posted by svho View Post
Guys,
33 NM torque
try this
https://www.castrol.com/en/global/co...ct-finder.html
      06-27-2023, 02:04 AM   #5
svho
Drives: X5
Not too late. I added the fill plugs to the cart but somehow got busy at work. I bought an extractor on Amazon. Will just pick up the oil this weekend.
Thanks,
TT
