      09-23-2012, 08:09 PM   #1
SerbX5
Serbia
Drives: E70 X5M
M5 Wheels fit on X5
Just sold my 2007 M5 and have the winter wheel/tire combo sitting in my garage. Will these fit on my 2011 X5 xdrive50i? Just curious.. need winter tires and would rather throw on the brand new winter setup from the M5 then buying new wheels/tires.
      09-23-2012, 08:46 PM   #2
335i_4D
Now in the dark side !
335i_4D's Avatar
Drives: 2011 911S 997.2 Cab
For the tires, don't think so, but just to be sure, on Tire Rack site.
For the wheels, I do think that they have the wrong offset, and the center bore is maybe also too small.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey)
Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed)
2010 X5 35d Black fully loaded (Sold)
2007 335i sedan Antracite (Sold and missed !)
      09-23-2012, 10:01 PM   #3
SerbX5
Serbia
Drives: E70 X5M
Thanks.. I forgot they are 18's as well. I'll call up BMW but I think you are correct
      09-24-2012, 03:40 PM   #4
az34
az34's Avatar
Drives: 2009 z4sdrive35i 2008 x5 3.0i
why do'nt you just try to install one.
      09-24-2012, 04:19 PM   #5
335i_4D
335i_4D's Avatar
Finally, decided to do the search for you
Offset is right, but center bore won't fit:
Car Years Bolt pattern Thread OEM hex Hub Offset
M5 2006-10 5x120 12x1.50b 17mm 72.6 +47
X5 2011-12 5x120 14x1.25b 17mm 74.1 +48
Tires
M5 255/45R18 27in high
X5 255/55R18 29in high
For the wheels, you'd have to get them machined to 74.1 (or buy spacers that convert from 74.1 to 72.6).
Also, and it may sound bizarre, but try to fit an X5 bolt thru the wheel.
I'm not sure, but they may not fit.
If they do, you should have the wheels.
Tires will definitively be too low (a full 2 in, which converts to 6% in tire size difference).
Usually, it's not recommended to go below 2%.
I've calculated the tires for the M5, since they don't list M5 as being able to use 18"...
      09-25-2012, 12:01 AM   #6
SerbX5
Serbia
Drives: E70 X5M
Tires
You my friend are an incredible man! Wow.. I owe you a beer. Thank you for the insight. I have listed them for sale.. as your right about the entire diameter being smaller, I should have put two and two together before the post. Appreciate it!
