      01-25-2019, 06:19 PM   #1
N62B48
N62B48's Avatar
22
Drives: XDrive 4.8i
E70 rear end links.
DIY: Replacing Rear Sway Bar End Links
Problem:
As you drive around or especially while turning the curve you can hear small knocking that sounds like metal to metal knocking sound The noise appears to come from under the cars rear.
The connecting links wear out over time. When they begin to fail, you may also have a knocking noise in the front end when driving over bumps or when steering the vehicle. To inspect the stabilizer links, jack the front of the vehicle and wiggle the wheel back and forth. While wiggling the wheel, listen for a noise from the link. If no noise is heard, place your hand around the ends of the link and monitor for looseness as you wiggle the wheel. The rear link has a rubber bushing the stabilizer bar inserts into. These wear out and cause a clunking sound. If you have a noise in the rear, this is a good place to start looking.
Tools need:
18mm socket, t-40 (solid core) star socket, 18mm open end wrench and brand new pair rear end links.
      01-25-2019, 06:56 PM   #2
argento
argento's Avatar
538
Drives: 2013 X5M
Nice writeup! Thank you!
      01-25-2019, 08:55 PM   #3
9vapors
Drives: CB X5M
I did this as well a few weeks back. Mine were very dry rot and clunking. Need to do the fronts too, but it's too cold right now here... lemforders as well. Couple pics in my thread on page 5... 9's X5M https://www.xbimmers.com/forums/show....php?t=1548291
Btw, how does that tile not crack from the weight of the car under the jack wheels?
      01-25-2019, 11:35 PM   #4
N62B48
N62B48's Avatar
22
Drives: XDrive 4.8i
Thank you.
I did the both front end links few months ago, the tile..hmm i dont know surprisingly never, not single crack everytime i worked in all my cars, not to mention i had landcruiser/ lexus lx weight about 6500lbs compared to x5.
      01-26-2019, 12:50 AM   #5
9vapors
Drives: CB X5M
I need to buy some stock in that tile haha... how were the fronts?
      01-26-2019, 11:14 PM   #6
DL335D
DL335D's Avatar
580
Drives: 2013 e92 M3 Q4
Unless your Land Cruiser/lx450 is set up as an overland rig the x5 has it by a few hundred pounds. E70s are tanks!
      01-27-2019, 12:58 AM   #7
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Thanks for posting this up, just ordering some for my X5M as i am hearing knocking sounds from the back while driving on rough ground.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
IG: @060Motorsports
