      10-04-2012, 01:09 AM   #1
mmmmQuattro
mmmmQuattro's Avatar
Australia
259
Drives: f83 / E93 335 / E70 X5 40d
Lowering - use links or use DIS?
Hi,
I am going to get the Eibach lowering kit.
Here in Australia, only the 7 seat ones come with the rear air suspension.
Eibach only provide the front springs, so I either need to buy the adjustable links or get the dealer to code it in.
What's the recommended approach?
      10-04-2012, 10:12 AM   #2
finagle69
Drives: '08 X5 4.8i
I like learning new things and DIY'ing. So I found DIS online, learned how to use it, and re-calibrated the rear ride height myself to go with my Eibach fronts.
Overall cost will be about the same, as it costs close to $100 for the adjustable links or the coding cable. The easiest of course will be the links.
      10-04-2012, 06:19 PM   #3
watrob
watrob's Avatar
Australia
140
Drives: MY2022 X5 M-Sport 45e White
Originally Posted by jp330Cic.au View Post
Hi,
This not correct, when the LCI X5 came out you could get self-leveling suspension without the extra seats, I have it on my M50d as well as AD?
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked.
      10-05-2012, 10:18 AM   #4
mmmmQuattro
Australia
259
Originally Posted by watrob View Post
This not correct, when the LCI X5 came out you could get self-leveling suspension with the the extra seats, I have it on my M50d as well as AD?
Opps, what I meant as it is a 7 seat one, it will have the self levelling suspension as standard or factory option on others.
It seems that in the US, all have the self levelling rears.
      10-09-2012, 09:47 PM   #5
skunkd
skunkd's Avatar
18
Drives: 2004 STI 2008 BMW M5 2004 530i
I already have the cable where can I learn to do this? any links?
      10-10-2012, 05:43 AM   #6
mmmmQuattro
Australia
259
I had a look over here: http://bmwcoders.com/
but it seems like a lot of work.
someone recommended to go here http://www.bpmsport.com/coding.php and get it done remotely.
      10-10-2012, 10:14 AM   #7
skunkd
skunkd's Avatar
18
well I'm familiar and have all the hardware and software, just never coded an X5 yet. mostly 3 and 5 series.
      10-10-2012, 10:16 AM   #8
finagle69
Drives: '08 X5 4.8i
there's a good bit of info on bmw coding . com (put that all together) and specifically the Diagnostic Software sub-forum of bimmerforums.com
      11-30-2012, 03:38 PM   #9
skunkd
skunkd's Avatar
18
forgot to ask... How is the ride lowered?? can you tell the difference? I have 22" wheels and its ok on the stock springs, but i'm worried if I lower with springs it will be too harsh for daily driving???
      12-04-2012, 10:19 AM   #10
finagle69
Drives: '08 X5 4.8i
With the Eibachs, it's only marginally stiffer than the stock (sport) springs. It's very difficult to tell the difference really. I'm on the stock 20's
      12-04-2012, 06:16 PM   #11
skunkd
skunkd's Avatar
18
I keep hearing the Eibachs are less harsh than the H&R's.
although I'm not sure if people are talking about the 2" drop spring from H&R or the 1.2" when comparing them to the Eibachs. Because the 2" drop springs actually drop about 2.5 inch so of course thats going to be really harsh.
Thanks you so much for that link. I'm dl'ing right now really awesome download speed from Dropbox.
      12-05-2012, 11:12 AM   #12
finagle69
Drives: '08 X5 4.8i
The only instance I've found online of someone actually trying both sets of springs were both the 1.2" drop of each company. And on a 4.8i.
Basically they liked the ride of the Eibachs over the H&Rs.
      10-07-2014, 10:52 AM   #13
wowdao
Drives: 2007 BMW X5 4.8i
Is there a way to lower the SUV with coilovers all around? Taking out the bags...
