12-10-2016, 08:16 PM | #1 |
Rep 30
Notification That Trailer Brake Lights are Not Working
When I hook my trailer up, I get a notification asking me to check the brake lights on the trailer. I did, they seem to be working fine. I tried unplugging and replugging the trailer wiring harness.
Any thoughts? |
12-10-2016, 08:33 PM | #2 |
Rep 79
If the trailer lights are LED, that's most likely what's causing the issue. Sometimes mine indicates my left trailer bulb needs to be checked the first time I start my X5 with the trailer connected. The notification clears and the brake lights always work.
2013 Jerez Black E92 M3 DCT ZCP | PFC Z54/Z45 BBK | MCS 2-way Remote Dampers | Hypercoil 600/900lb Springs | Ground Control Race Camber Plates | Bimmerworld Control Arm Bearings | Powerflex Sway Bar Bushings and Shock Mounts | EDC Delete | Macht Schnell Stage 2 Intake | Akrapovic Exhaust | Bimmerworld Race Studs | CSF Radiator | CSF Oil Cooler | Bimmerworld Power Steering Reservoir | Euro MDM | Lux H8 160 | BMW CF Front Splitters | BMW CF Competition Rear Spoiler | Schroth Quick Fit Pro | HRE R43
12-10-2016, 09:01 PM | #3 |
Rep 30
Interesting. I haven't drove it but more than 10 minutes or so. It did not clear in this time, at least that I noticed.. All the lights are tungsten wire, except perhaps the two brake lights, they are bar shaped, they might be led.
I guess that makes sense if they are on a discrete circuit to be illuminated when the brakes are pressed. Maybe I can add a resistor in line to mimic the resistance of tungsten wire? Chris |
06-20-2017, 06:27 AM | #5 |
Rep 3
Trailer Programming
11-10-2017, 12:38 PM | #6 |
64
Rep 750
Interested in a response on this one too! My have to get the coding looked at again like in borderm3's case
similar situation for me, however brake lights never worked all other lights worked. Last edited by adriang; 12-03-2017 at 07:01 PM.. |
