05-10-2022, 03:24 PM | #1 |
Rep 23
E70 bushings
So I've noticed that when I search for replacement bushings, almost everything that comes up had the various control arm and suspension pieces they are connected with as part of the kits. Is there a reason for this? Does no one sell just the bushings? Are these just as prone to needing to be replaced as the BMW 3 and 5 series cars? And lastly, are the shocks mounts prone to failing like most of the cars BMW made during this era?
05-10-2022, 03:53 PM | #2 |
Rep 994
You can buy these: https://www.powerflexusa.com/shop/ca...2007-2013-1818
I have the Front Radius Arm To Chassis Bushing in street form. I can't tell the difference at all from the stockers it replaced.
05-11-2022, 02:55 PM | #3 |
Rep 282
Here are my reasons:
1. The tension strut which has the most failure prone bushing also has a ball joint on the other end. The ball joint probably doesn't go bad very often but I didn't want to do the same job twice on the off chance it did. 2. Just new bushings requires a press - I would have more down time, have to drive to a shop, and have to pay them to press the bushings in. Im sure it wouldnt be too much but would also need a place thats open on the weekend when I have time to work on the car Last edited by wcs531; 05-11-2022 at 03:07 PM.. |
05-12-2022, 10:55 AM | #4 |
Rep 994
Not all bushings need a press. A ball joint tool can often do it. A torch can too. A hacksaw or similar can take care of the remaining metal sleeve.
Now if you're putting back in stock/OEM bushings, then yes most likely you need a press, as many of those are captive with a metal sleeve. |
05-12-2022, 01:10 PM | #5 |
Rep 282
Good point on aftermarket bushings not requiring a press. I probably should have researched poly bushings a little more but remember hearing about them getting noisy eventually.
How many years/miles have you had them? Have you had to re-grease them and if so do you have to remove and reinstall completely? |
05-12-2022, 03:44 PM | #6 |
Rep 994
Two things make all the difference in poly bushings.
Some brands have a cross hatch grooves within the inner race of the bushing. This provides a captive space for the grease to live and stay. The brand/type of grease you use makes all the difference too. I absolutely love Energy Suspension Formula 5 grease for bushings. Lasts years with no reapplication. I've been using this stuff for more than a decade on multiple cars. Depending on application, you can further augment this with a wrapping of plumbing teflon tape. Swaybar bushings are a good example of this. tape + grease is an unbeatable combo. |
wcs53196.50 |
