09-12-2018, 01:56 PM | #1 |
Rep 471
Anyone add air helper springs to an e70 that's non-factory leveling?
Towing quite a bit with my 35i e70. I have the factory hitch, but do not have factory air leveling.
Anyone add helper springs like the Air Lift 1000 kit? Just curious how it worked out before I spend the cash. https://www.airliftcompany.com/produ...air-lift-1000/ Would like to eliminate some squat when hauling a larger trailer or my boat.
08 Montego Blue 135i Coupe // Sport Package // Custom E30 tune // str8shot bluetooth enabled ECA // Walboro 255 inline pump // BMS downpipes // VRSF 7" FMIC // Injen intake // Berk ceramic exhaust // OEM 550i clutch // MFactory single mass flywheel // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless brake lines // Turner 15mm spacers
09-12-2018, 02:11 PM | #2 |
Rep 18
I had a 2006 Chevy Tahoe I used those same bags on. They worked great for pulling my boat. Just make sure you air them up before adding any weight to the hitch. You can air them down some once the weight has been applied to soften the ride. You will have to play with the air pressure a few times to get it just right. Just remember not to add air once the load is on the hitch. You run a chance of them rubbing and getting a hole if you add air after weight is applied. I hope that helps.
