      08-20-2018, 01:15 PM   #1
GWOCwinston
GWOCwinston's Avatar
Drives: E70 35i - E46 M3 - F30 330E
2013 E70 35i oil leak woes......wah wah wah
2013 e70 35i, N55 motor, 75k - running MHD stage 2, catless DP, BMS intake. Car has run rock solid and now I'm starting to see a lot of oil leaking. For sure its the OFG and VCG. Replaced them and now its starting to look like the oil pan gasket. Anyone have experiencing replacing this? Looks to be a hard job.
Here is a small list of maintenance items since ive had the car at 50k. Anything else I should be aware of that's "common" failure?
55k - tires all 4
60k-water pump replacement and thermostat
65K - plugs , transfer case fluid flush , front axel replacement + airbag (recall)
70k - new brake pads and rotors all 4
75k (current) - OFG & VCG & belts
      08-20-2018, 05:35 PM   #2
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
Oil Pan Gasket is a real PITA. I believe the entire front suspension and axle needs to be dropped. Unless youre a pro, i'd be careful.
I'd check with an indy
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
      08-21-2018, 08:52 AM   #3
SerdarAlemdar
Drives: E70 Bmw x5 35i
55k - tires all 4
Hi just wondering where you got performance upgrades done what sort power gain have you got out of it and a rough cost. Sorry for questions new to forum and looking at performance options
      08-21-2018, 09:53 AM   #4
GWOCwinston
Thanks for the suggestion. I am having my indy do the job. replacing all the gaskets - OFG -VCG - OP - flush brake fluid - flush coolant. Not cheap, but the car has been somewhat problem free and I'd like to get another 25-30k out of her before I get rid of it.
      08-21-2018, 12:12 PM   #5
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
Unless they are gushing oil, none of those will prevent you from getting another 25,000 miles out of it. if that was my plan, no way I would pay the expense of paying someone to do all that work. Probably $3k of work there and no one will care when sell it (at least not enough to pay extra for it)
      08-21-2018, 01:25 PM   #6
GWOCwinston
I agree. however it was gushing oil real bad. Leaving oil stains in my parking garage and driveway. I also noticed the oil level dropping every week. I can do the top end gaskets myself. However, since I was bringing it in for the oil pan. I just had the Indy do it. I'm paying just under 3k for the work. It is what it is but at least I wont be leaking oil anymore.
      08-21-2018, 03:33 PM   #7
Nexo
Nexo's Avatar
Drives: E70 x5 2011
2011 X5 e70  [0.00]
I have a similar setup. VSR D/P - intake - MHD flash - KW v3 coilovers. I'm beginning to notice some oil near the back of the motor. i didn't do the valve cover so the original PCV is in place and I just hit 70k miles. Did you hear the tell tail hi pitched whine? or the chirping sound?
      08-21-2018, 07:27 PM   #8
Hal88
Drives: 2013 X5 335i
I have the same X5 and the same oil pan gasket, dealer quoted me $2500, indy shop $1000, however it only leaks when I don't drive it for about a week since I have a commuter car for work. If the leaks are not too bad you can postpone until it gets really bad. And yes it is a big job and u need a pro to do it.
      08-21-2018, 08:19 PM   #9
racermp
racermp's Avatar
Drives: F30 330i
Do the ofhg, that's the one leaving oil on driveway and the deadliest. The rest can wait.
Hahah sorry missread. Yeah oil pan is a pain, especially on a 4wd N55. See if an Indy can do it for u.
      08-22-2018, 12:46 PM   #10
GWOCwinston
No sounds from the car really. Just massive oil leaks. car drives like a dream too! The big tell tale sign was that I cleaned the engine bay and under as best as I could, then I had the car sit at idle for an hour. Went back under the engine and oil was spewing out of everywhere. More specifically the oil pan. I went ahead and bit the bullet and just brought it to my indy.
      08-22-2018, 12:49 PM   #11
GWOCwinston
Agree, oil pan sucks on the N55 with AWD. I looked at doing it myself and decided not too. BIG JOB. Having my indy do all the work and a bit more on the side. Truck has been problem free since I've owned it and I can justify the maintenance cost if it can get me another 30k. My only worry is the turbo, hope it lasts for a long time as the bolts are rusted on there pretty good from winter driving up to Tahoe.
      08-22-2018, 12:58 PM   #12
Nexo
Nexo's Avatar
Drives: E70 x5 2011
2011 X5 e70  [0.00]
do you mind me asking what was the cost and what state do you live in I'm in New York City. I have a leak in rear main seal but I have not verified that 100% and I have yet to replace the valve cover so I'm not sure what condition my PCV valve is it that's why I asked if you have the whistling or chirping
