      08-12-2014, 12:29 PM   #1
Kerrazy
Drives: X6M
Tire Pressure?
What you guys run on your X6M with the the factory 21" set up? doenst really say in manual whats best. I have 285/35 R21 , 325/30 R21.
Curious what you guys put in, I was told 45psi for rear and 40 for front for highway and carrying 2-4 peeps with luggage
      08-12-2014, 05:45 PM   #2
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
I am running 22's and set my pressures at 32-34 psi for all corners. door sticker says 38 psi for 20's but I found that a little harsher ride. Not sure if the 38 psi is specifically for runflat spec.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      08-12-2014, 09:57 PM   #3
daytona1712
Indonesia
Drives: X6M
Run 36psi for front and 34 for rear on my 20' setup and will keep it that way on my incoming 22' wheel too.I though (plz correct me if i wrong) we should run front end higher then rear because front is always heavier then rear.
