      07-23-2014, 08:45 AM   #1
bmwstve
Drives: BMW X6, MHD Stage 2
Roof Rails for X6?
I'm planning to purchase a set of aluminum roof rails for my X6
but upon further inspection, I noticed that my roof mouldings dont have any
openings on them for the roof rails to be bolted.
they dont have this : http://i879.photobucket.com/albums/a...s/IMG_6544.jpg
So are the roof rails compatible with my X6?
see my attachments for reference
thanks
      07-23-2014, 05:35 PM   #2
Tailwinds
Drives: X6m
I remember someone else asking this. I think they were told you must and can get the parts from BMW that allow the rails. It requires replacing the mouldings I think.
      07-24-2014, 09:13 AM   #3
imsag
imsag's Avatar
Drives: 2010 X6 35d
Check this thread - http://www.xbimmers.com/forums/showthread.php?t=980061
You need the trim number 5 with the holes in it - I have the opposite problem!
2010 BMW X6 35d | Alpine White | Black Nevada | 21" Ferric Grey Style 215 Wheels | Colour Coded | Media | Dynamic
Done: 2014 Map Update
To Do: Lux Angels | LCI Tails | Remove Running Boards | Remove Roof Rails | Reverse Camera Retrofit | Spare Wheel Retrofit
      07-24-2014, 09:34 AM   #4
Barbja
Drives: 2020 X4 M40i
You could wait and if you ever have an accident where the airbags go off and bam! The headliner will be right out of ther for you. (Headliner, steering wheel, maybe dash, probably windshield...)
One of the hitches with that plan is that you may not get the car back, which is a bummer.
      07-25-2014, 09:51 AM   #5
bmwstve
Thanks!
I've searched the part number, its 51137250399 (left) and 51137250400 (right) around 130usd EACH. Quite expensive for a piece of plastic!
Can't I just have a professional drill the needed holes on my existing roof moulding?
Is attaching roof rail an easy bolt on? or should I still remove the headliner?
Thanks
      07-28-2014, 06:45 AM   #6
bmwstve
How do I install the roof rails?
Is it a direct bolt on
or
Does it require drilling and removal of the headlining?
