      07-16-2014, 11:24 PM   #1
bmwstve
Drives: BMW X6, MHD Stage 2
LUX V4 vs DTEC V9.5 vs MTEC V3 LED Angel EYES
Hi everyone!
I’m in search of the best LED angel eyes for my 2011 BMW X6 35i.
Which one is really the best in terms of brightness and reliability??
I’ve searched several forums for countless hours and I can’t come up with a final decision on which LED angel eyes to order.
I narrowed it down to 3 choices:
• MTEC V3 7000K
• DTEC H8 V9.5
• LUX V4 Color adjustable Angel eyes – I kinda like the fact that I can change the colors of my angel eyes
Which kit is most visible on direct sunlight?
Which kit doesn't have the “flickering problem”
Please help me decide so that I can finally place my order.
Thanks guys!
      07-17-2014, 01:45 PM   #2
crunchingnumbers
crunchingnumbers's Avatar
16
Drives: 2022 X6M, 2018 RRS
I installed Lux V3 Angel Eyes in my 2012 X6 5.0 and they worked flawlessly (great brightness/color, error free, no flicker), so much so that I removed them when i handed in my 2012 and put them in my 2014 X6 35 m sport yesterday.
I don't know the other brands, but I think you'll find general agreement on here that the Angel Eyes are a great product. The V4 can only be better.
      07-19-2014, 07:48 AM   #3
bmwstve
Great!, thanks for the reply
      07-19-2014, 07:59 AM   #4
Barbja
Drives: 2020 X4 M40i
I had LUX V3 in my 2012. They flickered when I started the car, which I only noticed if I started it in front of a store window. Otherwise they did not flicker.
      07-19-2014, 08:56 AM   #5
bmwstve
I've also read some reviews that Lux do flicker sometimes.
How about Dtec/Mtec has anyone used it?
      07-25-2014, 12:19 PM   #6
asn
Drives: Current S2000 & MDX Future X6
tagging along
      07-30-2014, 02:22 PM   #7
wildaperture
wildaperture's Avatar
Drives: 2012 BMW X6 50i
I just checked out DTEC's site. There's a DTEC V8 H8 with 90W 3600 Lumen Output. Too bright?
I also like the LUX H8 V4 gives you the options from white to blue.
///M wanna be
      07-30-2014, 02:46 PM   #8
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
MTEC works perfect. Honestly, you can't go wrong with any of these. Throw a dart.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      08-03-2014, 01:12 PM   #9
spaniard
spaniard's Avatar
Drives: 2015 BMW X6M
Check this out if you want a WANNABE BMW LED Adaptive Headlights: http://www.m3post.com/forums/showthread.php?t=723053
      08-06-2014, 07:59 AM   #10
wildaperture
That's nice but if I were to spend that amount on replacing headlights I would much rather going with the latest OEM adaptive LEDs.
///M wanna be
      08-07-2014, 07:49 PM   #11
asn
Just a thought/question.
Couldn't you (or I) swap out the M8 bulbs for some with a whiter color to them? That should only cost $25-30 and be the same brightness as the OEM bulbs, without worrying about codes or LEDs
      08-08-2014, 01:01 PM   #12
badblkX6
Drives: 2014 X6 35i
I went with the LUX V4 on my X6. They look much better than the stock amber looking bulbs, but they still aren't super bright and don't stand out in daylight conditions like the adaptive headlights that come from the factory.
I am pretty sure they are all the same. After the first install of the V4, I haven't messed with changing the way the lights like (white to blue) so that isnt a very important or crucial feature for me to have.
I did notice that my V4's do flicker on startup. I too noticed this by seeing it in a store window reflection.
      08-08-2014, 01:27 PM   #13
HPIA4v2
Drives: F80, F86
The cheapest route is to use blueish tint H8 bulbs (still halogen), but IMHO, well it cheap solution so don;t expect much as far as light-output. It also more blueish tint instead of white. you can buy $15 for the pair.
I have the ole H8 20W LED bulb and H8 DTEC 64W. I like DTEC cause I don't need to change the color, white is what I want with max light output.
Not sure if the latest DTEC will make E71 X6 (w/o LED headlamp option) any brighter, the optic is the limiting factor not the LED bulbs. By optic I mean the circular plastic rings that make up the angel eyes.
      08-08-2014, 03:58 PM   #14
asn
So, wouldn't these work? They are the same size, and wattage as the OEM's, but are whiter.
http://www.amazon.com/GP-Thunder-SGP...productDetails
      08-08-2014, 10:41 PM   #15
Tailwinds
Drives: X6m
FYI, I have stock lights on 2012 X6M and they flicker on start up.
      08-12-2014, 11:20 AM   #16
LuxAngelEyes
LuxAngelEyes's Avatar
They will work yes. The problem with colored halogen bulbs is that you have a yellowish filament covered by a blue glass. This in turn will make it less yellow overall, but greenish in color. Since the angel eyes are never at full power the appear more green then intended, especially when the headlights turn on.
      08-12-2014, 10:00 PM   #17
asn
That doesn't make sense. Why would they list them with different color temps ie: 6500K / 7500K / 8500K / 9500K if they end up being green bulbs?
I am sorry, but am I missing something?
      08-13-2014, 11:49 AM   #18
LuxAngelEyes
Well let me explain a bit more then since my previous answer was a bit confusing. There are many shades of white and that color falls within the "black body curve" of the CIE 1931 chart. Anything that falls within the black line is a pure white, and if the color is above that it will have a green hue, and below that will have a red hue. Most colored halogen bulbs will fall above the black body curve making them appear greenish in color
