      01-26-2014, 02:15 AM   #1
Joyaant911
Drives: 2007 x5
Front suspension noise
Got a tremble sound everytime I hit a bump. Kinda sounds like when a shock mount goes bad.. Any ideas?
      01-26-2014, 11:54 AM   #2
zoex5m
Drives: x5m
I would like to know as well. I brought the car into the dealer and they retorqued a few nuts up front. Sounds better but still hear noise coming from up front on occasions.
      01-27-2014, 10:35 PM   #3
Mamba003
Drives: 2010 X5M
I had rattling noise coming from from drivers side and it would up being sway bar mount. Was fixed under warranty. Two weeks later passenger side went. Same thing. Have x5m
      01-27-2014, 10:46 PM   #4
Joyaant911
Drives: 2007 x5
Apparently my front struts are messed up. Wondering if it's the actual strut or strut mounts
      01-28-2014, 09:33 AM   #5
Spaceballs
Spaceballs's Avatar
Drives: 2010 Space Grey X5M
Sway bar links.
I had mine replaced. Both sides, dealer fought it the whole way to be covered under my warranty.
'10 Space Gray, Cinn Int.
      03-10-2014, 03:16 PM   #6
Joey.Donatelli
Joey.Donatelli's Avatar
Drives: M5C
How can I inspect this on my own before taking it to the dealer?
      03-10-2014, 03:18 PM   #7
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
Get a creeper, crawl underneath, have someone else drive the car. Don't forget your flashlight.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      03-10-2014, 03:26 PM   #8
Joey.Donatelli
Drives: M5C
Perfect!!! On my way out the door and I have 2 flashlights just in case.
      03-11-2014, 11:54 AM   #9
Joey.Donatelli
Drives: M5C
Anyone? I have an appointment at the dealer tomorrow and I would like to inspect this myself before taking it in.
      03-11-2014, 01:34 PM   #10
JVX6M
JVX6M's Avatar
Drives: 2023 BMW M3 Comp
I'm also getting this sound at low speeds over bumps, I'm sure the dealer will tell me that it's because I'm lowered on a spring kit and probably won't cover it under warranty I'm guessing. Let us know what happens!!! Is your X5 lowered at all?
      03-11-2014, 03:38 PM   #11
Gerryballz
Drives: X5M
I was getting the same noise with my dinan suspension. Dinan replaced all 4 shock mounts back to the oem ones and that fixed it. They did it all for free...
      03-14-2014, 11:37 AM   #12
Joey.Donatelli
Drives: M5C
Took my X in yesterday for front suspension noise. When I dropped it off I told the tech that I assumed it was the sway bar links or the strut mounts. He replied "Ok that makes my job easier." I got a call about an hour later telling me that it was in fact the sway bar links. So they replaced them under warranty and then let me know that they also went ahead and replaced the strut mounts as well.
All is good and no more noise!!
      03-14-2014, 03:55 PM   #13
Spaceballs
Spaceballs's Avatar
In case anyone reads this thread later and wants to know how to check to see if they are bad, you need to get it onto a lift prefereably-it needs to be off the ground to have the suspension unloaded. You can then move the sway bar ends if they are bad.
      03-14-2014, 04:15 PM   #14
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Good info. I have noticed when I drive over a bump or a steep incline sideways (when the car flexes) a noise in the front suspension also. My X5 is under warranty until October. Thanks for the tip!
      03-14-2014, 04:27 PM   #15
rennis
rennis's Avatar
43
Drives: E70 5.0 & B5 S4
I need to get mine in soon. This noise is driving me nuts.
I hope they don't question the repair under warranty (it's on H&Rs)
      03-14-2014, 06:57 PM   #16
JVX6M
JVX6M's Avatar
I am in the same boat also on H&R's. I Don't remember hearing the clunky sound before the springs but also haven't even had them on a year yet.
      03-14-2014, 09:34 PM   #17
skunkd
skunkd's Avatar
18
Drives: 2004 STI 2008 BMW M5 2004 530i
mine too on h&r's. I wonder if lowering it causes them to wear out very quickly.
Anyone know the cost of the repair per side at the dealer without warrenty coverage?
      03-15-2014, 11:06 AM   #18
rennis
rennis's Avatar
43
Mine was clunking even before I lowered it. I'm sure the lower geometry doesn't do it any favors though.
      03-15-2014, 11:32 AM   #19
Joyaant911
Drives: 2007 x5
So everybody's having issues with front sway bar links after h&r install? I'm gonna be installing these in like 2-3 weeks should I purchase new ones
      03-15-2014, 01:22 PM   #20
zoex5m
Drives: x5m
^ No. Mine is still factory height and the noise came.
Check out this thread. I listed all the parts that were replaced when I brought mines into the dealership.
http://www.xbimmers.com/forums/showthread.php?p=15489810#post15489810
      04-14-2014, 05:23 PM   #21
Joyaant911
Drives: 2007 x5
http://www.xbimmers.com/forums/showt...0#post15489810
Thanks for this.. I've been having this god awful noise even before the suspension install or lowering I assumed it was shock mounts and I was doing everything at once so I figured I'd be good. I did bilstein sports with the H&R kit and also shock mounts. To my surprise noise still exist!! Wasn't my mounts or any of the above so now I'm gonna change links and also sway bar bushings see what happens then.... Hopefully all good
      04-14-2014, 05:28 PM   #22
zeroboot
Drives: 2011 X5M - sometimes
Had a similar noise, clunk sound at low speed when turning into or out of the driveway. Ended up being loose stabilizer links. They are on the way, not sure why they have to come from Germany though, seems like a popular item.
