      09-15-2019, 11:26 AM   #1
blakeblk89
blakeblk89's Avatar
Drives: BMW X5 50i, BMW X6 50i
Question 2013 X5 50i E70 N63 HPFP "High Pressure Fuel Pump"
Well hello there everyone I'm pretty much new to this and wanted to receive some input on this particular vehicle and also for future Bimmer rides as well.
Ok, so here's the story I recently purchased this beautiful 2K13 X50i 4.4L E70 N63 and it has been running marvelous for the past couple months. I took a vacation from work since it was time for it and I thought to take it out of state.
Prior to to doing so it shows on the Gas door minimum octane rating is 89. which I've never put in any foreign car. so I've been putting 89 ever sense. A week later check engine light appeared "reduced power".
Did some research, I have a scanner CODES P0300, P0305 P0306, P0307 P15EF pending, P01C8 pending, P0308, and also to confirm the issue and had to spend a little bit took it to the dealer and all leads to Banks 2 HPFP. I'm getting misfires on cylinder 5,6,7,8 before it wasn't reading 7 only 5 and 6. and now 8.
I also noticed there really isn't much information on Changing these parts. So I will be making a thread on how to replace the HPFP.
has anyone experience such an ordeal?
The other HPFP on Bank 1 seems fine no misfires and I've been putting 91 and above. should I replace that as well, I mean if it's not broken don't fix it right.
Thanks
      09-15-2019, 11:51 AM   #2
NorthCountryGuy
The Quiet One
NorthCountryGuy's Avatar
1713
Drives: M6, E70, E71
2013 X6 M  [0.00]
2013 M6  [0.00]
2013 X5 LCI 35i Spo ...  [0.00]
2013 X5 LCI 35i  [0.00]
https://www.newtis.info/tisv2/a/en/
Use the above link. Select your vehicle. These are the workshop manuals.
Great looking X5.
2013 M6 Coupe Sakhir Orange Metallic / Sakhir Orange \ Black Merino - The Prince
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse
2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s
2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s
      09-15-2019, 11:56 AM   #3
NorthCountryGuy
The Quiet One
1713
2013 X6 M  [0.00]
2013 M6  [0.00]
Welcome to the Forum.
      09-15-2019, 02:03 PM   #4
Sophisticated Redneck
Drives: 2012 BMW X5 50i
It's a pretty basic part to replace and one of the easier ones. Check out newtis as mentioned above and get the part yourself, the oem Bosch pump is about 300ish dollars of you go to BMW your looking at about 1400 dollars just for the pump. Should take you less then an hour to do. Coupl things to note: get a Full face sheild off Amazon. Don't get me wrong, I like squirters just as much as the next guy but getting hit in the face with gas at 2000+ psi (rare but possible) is not my idea of a good time. Be absolutely meticulous with cleanliness around the fuel fittings and make sure you get the correct torque on the fittings. Some people have reported being able to install the pump in even with the pump piston on the high part of the cam lobe by gently tightening each side of the pump one half turn at a time. BMW tells you to rotate the engine if this piston isn't bottomed out, which means your pulling your front brace and cooling fan to get the the crank bolt..
      09-15-2019, 02:55 PM   #5
blakeblk89
blakeblk89's Avatar
Smile
Great looking X5.
Thanks You Thanks You I'm a individual that's very handy. I had a sedan 2005 530i E60 and did my own maintenance as well until I sold it. I'll post a pic soon and excellent manual beyond words. greatly appreciate it.
Just 2 questions boss....
Is it necessary to pull out ignition coil? looks like #6
and if I have to I will..
but do i have to release pressure on the injector lines since I'm letting it sit over night?
Thanks again..
      09-15-2019, 03:00 PM   #6
blakeblk89
blakeblk89's Avatar
definitely feel welcome for sure. and I will wear a protective face shield ...
      09-15-2019, 03:54 PM   #7
Thanks again..
Depends...if your pump is bad one would think it wouldnt hold much pressure but even 500psi residual is nasty...some pull their fuses and let it run dry. Others just slap a rag over it and crack the lines. I take all precautions, direct injection is no joke.
Coils are super easy; rotate side to side to crack it loose (won't move much but about an 1/8), pull up on the release clip, pull it out, mind the wire harness doesn't get caught up on the way out. Thats it, no tools needed
      09-15-2019, 04:21 PM   #8
blakeblk89
blakeblk89's Avatar
I'll have as many towels as possible and ill disconnect negative terminal as well.
I just have to say I might not have new screws am I screwed lol?
      09-16-2019, 02:49 AM   #9
blakeblk89
blakeblk89's Avatar
Great looking X5.
Do I have to rotate the camshaft if need to in order to install the HPFP bank 2. And if I have to, facing the engine which direction does the engine rotate clockwise or counterclockwise and once finished is it necessary to rotate back to regular position
Thanks..
89MasterMind
      09-16-2019, 09:30 PM   #10
blakeblk89
blakeblk89's Avatar
Install feed fuel line
Hello there. Now to reinstall feed fuel line how's is that suppose to be put in. It's a touch cookie I'm trying to put it back in it's tight but I'm still not sure.
Thanks thanks
89MasterMind
      09-17-2019, 12:28 AM   #11
jiggz
Drives: E90 M3|F15 X5 50i
You should read up on the N63 CCP (customer care package) if you haven't already.
I had my HPFP's replaced for free by BMW under this campaign, along with a ton of other parts.
Tags
2013, 4.4l, e70, n63, x50i, x5i
