      04-11-2017, 05:52 PM   #1
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
Gear Oil for E70 X5M
Gents,
Wondering if any of you have swapped your own fluid and what you used. All the fluids in my truck were swapped at 30k miles and I'm due for another as I'm at 60k now.
REALOEM lists 75W-85 oil with two different part numbers for the rear diff. The first part number "Hypoid Axle Oil G1 3 X 0,5L X 07/2011 83222295532" is the only part number listed for the front diff. The other part number for the rear is "Final-drive unit gear oil SAF Carbon Mod 0,5L X 83120445832." I'm unsure what the "Carbon Mod" means. Both are BMW and both are $50 per bottle with 3 bottles needed for each diff. I can't imagine that the front diff would take that much oil but I expected the massive rear diff would take more.
I know you need to get OE tranny fluid 100% with these auto transmissions but I've never used OE diff fluid on any of my cars, usually redline. ECStuning lists about every gear oil available as being applicable to the X5M no matter the weight, but I've found that redline does sell 75W-85.
OE fluid is $300 to swap both diffs
Redline is $60 to swap both diffs
Recommendations on other brands or recommended weights for our trucks? I'm planning on swapping the t-case also but understand that you have to code the fluid swap and neither carly nor NCSexpert have the option...so indy I guess. I'm still debating on doing the transmission fluid drain and fill with filter swap myself.
      04-11-2017, 07:49 PM   #2
socale39
Drives: 04 545i SMG
I've used redline in the past for all my BMWs without issue. I'm about to do fluid changes on my 35d and plan to continue using Redline.
      04-11-2017, 09:03 PM   #3
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
Yeah, if I can I'll keep going with redline also. I put 75W90 in the wife's 3.0si recently but still unsure about the viscosity for the M. Real OEM states 75W85 for the front and rear, which is probably what I should follow, but ECStuning and pelican parts list 75W90 for the front and 75W140 for the rear. The assumption there I believe is that the X5M has a standard LSD like other M cars and not the torque vectoring diff?
Just called BMW and confirmed the oil is 75W85 in both and there appears to just be an extra bottle of 75W85 in the rear with the "carbon mod" maybe just an antifriction additive?
      11-02-2017, 09:21 AM   #4
philly42
Drives: X5M, Z3M
Did you end up replacing all your fluids? It appears that the rear diff has 3 compartments that use fluid and two different fluids are needed.
Any issues replacing the transmission fluid with the filter?
      11-04-2017, 01:35 PM   #5
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
I haven't done any of the fluids yet. I just placed an order for a Foxwell NT510 scanner which does coding and can actuate/reset systems. Hoping to use this device to reset the transfer case when I swap the fluids and also use it to activate ABS for brake bleeding.
      11-07-2017, 01:16 PM   #6
Kraftwerk AG
Kraftwerk AG's Avatar
Drives: Mein F Fünfundachtzig Einhorn
Yes, I'm looking to buy one as well. Looks promising! Here's a list of functions:
      11-07-2017, 04:47 PM   #7
jandref321
jandref321's Avatar
345
Drives: 2012 X5M
Yep, I got it Friday and did my brake lines over the weekend. The scanner is kind of complicated to get setup since you have to install the BMW software yourself from home, but it’s a great system. I ran the brake bleeding routine and got all the extra air out of my lines. It’s very easy to use and paid for itself immediately since the Indy shop was going to charge $300 to bleed the brakes with INPA.
      11-07-2017, 04:55 PM   #8
Kraftwerk AG
That's great news to hear! I did plan on using it for the bleeding procedure also. Any info on the transfer case function?
      11-08-2017, 10:26 PM   #9
philly42
Drives: X5M, Z3M
It took me a while to get used to using rheingold/ISTA. It's really worth it if you plan to service and diagnose issues yourself.
      11-09-2017, 02:41 PM   #10
Kraftwerk AG
Good to know. I'll have to look into that & make a comparison of the two. Although you can load up to 5 apps for different makes into the Foxwell NT510...
      11-10-2017, 01:25 PM   #11
philly42
Drives: X5M, Z3M
I'm not familiar with other programs but ISTA is what the dealer uses. It's a lot more user friendly than INPA. What I've used the program the most so far is to diagnose CEL. When there is a fault code, the program will give you a few tests that can be run to help figure out the true faulty item.
For example one of the tests I did was for a misfire. It build up pressure in the fuel line and measured within a time frame if there was a pressure drop. If so then the fault could be with a leaking fuel injector.
Tags
differential, gear, maintenance, oil, x5m
