      12-17-2016, 09:10 AM   #1
badge1
Drives: 2010 BMW X5 M
X5 M turbo lines or hoses?
Started to notice a bit of a burning plastic/rubber smell from under the hood. Initial thoughts were the engine partitions but upon popping the engine cover it looks like one of the turbo coolant hoses right at the top is brittle and, mixed with some burnt coolant is creating a bit of a mushroom right at the clamp.
It looks like this hose was replaced at some point because it isn't a crimp clamp but rather a screw clamp. It looks like this has just bit in too tight.
When talking to the dealership, thy say need to replace all coolant lines and expect a $3,000-$4,000 repair. Was a little shocked as it looks to be one four inch hose and clamp that are failing and from what I have seen on various forums looks like about $20 in parts.
My question is, at what point do you determine that all lines need to be replaced over just the hoses?
Many thanks in advance for your replies.
      12-17-2016, 03:53 PM   #2
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Pics would help but it's a good idea to replace the entire cooling system in most BMW's around 100k due to the excessive use of plastic...better to be proactive vs reactive. I myself do have a turbo coolant, drivers side, closest to the firewall. It's got a worm drive clamp as well, so I'm guessing the line has been replaced before. I've also noticed that the drivers front line (the one that runs over-the-top of the charge pipes) always seems to be under more pressure than others when I swear squeeze them, so I'm thinking I need to reverse flush the lines.
      12-17-2016, 04:22 PM   #3
badge1
Thanks. I can't seem to figure out how to upload from from phone but I posted three pics in the burning plastic smell thread a few threads down.
Appreciate your response M5James
      12-19-2016, 10:42 AM   #4
badge1
Pics are attached. What I have found out from dealership is that they do not stock just that four inch piece of hose, but rather they need to replace all the lines and hoses for a cost that looks something like $3,000, when all I need is a $20 hose. No thanks.
Some good info here but still some ambiguity on hose size: http://f10.5post.com/forums/showthread.php?t=1124308
Can anyone confirm inside diameter of hose size?
      12-19-2016, 09:27 PM   #5
badge1
One more bump on coolant hose inner diameter before just going to buy a few different sizes.
      12-19-2016, 10:38 PM   #6
m5james
m5james's Avatar
Haha, mines in the same area just on the drivers side. I don't know the diameter, but you've gotta remove it anyways so you might as well just take it off and take it with you to the store.
      12-21-2016, 06:42 AM   #7
badge1
Alright. So 1/2 inch hose and a couple clamps seems to have done the job for now. $10 in parts v. The $3,000-$4,000 (CAD) quoted by the dealer to replace all the lines.
      12-21-2016, 06:43 AM   #8
badge1
If you aren't connecting to that T (see pics) you could get away with 3/8 inch hose.
      03-13-2018, 12:07 AM   #9
TheVazha
Drives: X5Mmmkay.
My is up for replacement as well. That little 4 inch one is a Continental part but i have not been able to find it anywhere.
Does anyone have a solution that works?
      03-13-2018, 06:32 AM   #10
jcm3
Drives: F85 X5M, 07 911 TT
https://www.ecstuning.com/b-genuine-...e/11537598343/
      03-13-2018, 09:39 AM   #11
TheVazha
Drives: X5Mmmkay.
Thank you.
Do you think I can get away with replacing just the couple short pieces or do I need to replace the whole thing?
      03-13-2018, 02:09 PM   #12
jcm3
i recplaced the short peice only to find the other one starting to leak so i bought the whole line.
      03-13-2018, 02:25 PM   #13
TheVazha
Drives: X5Mmmkay.
Just replaced the short one with new clamps. Looks brand new, no sign of leakage. The guy didn't even want to charge me for the parts. I have him $5 anyway. Took about 3 min to swap!
      03-14-2018, 11:54 AM   #14
Colodano
Drives: 2010 X5M
Where does that longer line end up? I get a random coolant drip on that side, and it also has the ballooning top hose, so that whole hose might fix my issue as well.
      03-14-2018, 04:13 PM   #15
TheVazha
Drives: X5Mmmkay.
This guys deserves good karma
      03-16-2018, 11:18 AM   #16
greddy91
Drives: 2010 X5M
Ehhh, not to toss you a red herring here, but my burning smell had nothing to do with the coolant lines (and this was also the BMW diagnosis.)
The smell was from the plastics above the firewall. Give them a look at your convenience and make sure you're not chasing the wrong issue.
IMO anything over a couple of hundred bucks for the replacement of those top coolant hoses is ridiculous.
As you go through the process, be a great forum member and share your parts used, gotchas, and tips/tricks. I have yet to see a single model not afflicted with these wears and literal tears.
      03-17-2018, 04:04 PM   #17
chris604
Drives: X5 M
I had a quote from the dealer for $900 (CAD) here in Van. That was just for one side (forgot which). I smelled something burning, but didn't see anything yet. I haven't taken it all apart yet. I think it's about 5 hours labor though, that's why they charge so damn much. Theres a trick to refilling the coolant and bleeding the system as well, correct?
      03-22-2018, 08:40 PM   #18
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
I had all of mine replaced by an Indy for 300.
      03-22-2018, 09:50 PM   #19
m5james
m5james's Avatar
Other than upper and lower radiator hoses, all these ones related to the turbo that are straight/light bends can be replaced with bulk stuff from your local autoparts store. There's absolutely zero point to pay BMW's markup for anything so generic.
      03-22-2018, 09:52 PM   #20
m5james
m5james's Avatar
It's mostly self bleeding but if you search YouTube, there's bleeding instructions on there. It was something like ignition on, holding the gas pedal down for like 20 seconds and it'll activate all the pumps.
Dawgz1015.00
      04-24-2018, 08:16 AM   #21
pito2121
Drives: Bimmers!!
2012 BMW X5M  [0.00]
2013 BMW 135is  [0.00]
Ok this is what I was thinking. Replacing it with more robust parts like better thermal hoses and brass Ts. Are any of the Ts restrictors or check valves or are they just regular T fittings?
I have a burnt smell coming form my truck but haven't pulled the cover yet. Doing it this weekend but in the even why not upgrade and be done with this issue for good. Keep in mind those sinch, Pex clamps are good for Pex tubing not so much rubber. The thermal dynamics of Pex tubing is completely different than that of rubber. That's why the clamps lose grip with the changing of the temperatures. U now what that is, BMW creating a continuous maintenance cycle. Why do u think the lines are only $75 each yet people are being quoted ungodly amounts? Profits over Humanity!!!!!
      05-26-2018, 07:28 PM   #22
TheVazha
Drives: X5Mmmkay.
Will someone please post the part numbers of both hoses?
Thank you kindly
