      12-10-2016, 07:46 PM   #1
borderm3
Drives: E70 X5 M Sport
N63 Stock Data Log - Troubleshooting 0x310B
E R R O R M E M O R Y
Date: 10.12.2016 17:00:58
ECU: MSD85
JobStatus: OKAY
Variant: MSD85
RESULT: 1 error in error memory !
310B 0x310B Ladedruckregelung 2, Plausibilit‰t
Druck zu niedrig
Testbedingungen erf¸llt
Fehler momentan nicht vorhanden, OBD-entprellt
Fehler verursacht kein Aufleuchten der Warnlampe (MIL)
Error code: 31 0B 28
Translated to English via google
ECU: MSD85
JobStatus: OK
Variant: MSD85
RESULT: 1 error in error memory!
310B 0x310B Load pressure control 2, plausibility
Pressure too low
Test conditions
Error currently not available, OBD debounted
Fault does not cause the warning light (MIL)
I get the above code. Here is the thing, it happened when I towed for the first time. I got a notice on the dash regarding an engine malfunction and potential power decrease. Seemingly, there was no change in power. After I unhooked, I romped on it and no problems, no notifications. I hooked back up, pulled it, got the same code.
I speculate that there is a target boost pressure bmw expects and if you do not reach that within some threshold in time and amplitude, this code is thrown?
I ordered 2 new boost control solenoids. I am hoping this fixes it, if not perhaps a diverter valve is leaking? I don't suspect it to be a steady state vacuum leak since it never happens unless it is under the load of towing.
Can anyone think of anything else that could cause this under extreme load only?
I was hoping someone might have a 'stock' n63 datalog that I could use as a control and compare it to my car. I am using the bmw logger.
Thanks
Chris
      12-18-2016, 12:14 PM   #2
borderm3
I replaced both of the pneumatic solenoids for boost control, they did not fix the issue.
I am going to try to smoke test it to see if there is a boost leak.
      12-18-2016, 07:50 PM   #3
borderm3
As far as I can tell it looks like BMW's wastegates operate the opposite of a traditional wastegate, vacuum pulls the flap shut.
I am starting to think my problem is with the waste gate actuator not shutting under proper vacuum.
      12-27-2019, 04:25 PM   #4
525DA_touring
Drives: BMW E88 125i 2007; BMW E70 X5M
And now ?
      12-27-2019, 08:07 PM   #5
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Originally Posted by 525DA_touring View Post
And now ?
Looks like this thread is super old but I will add some notes here in case anyone else gets this code:
On the N63, you can adjust the wastegates actuator arm fairly easy as they become worn with time. From the factory the wastegates are set to be firmly closed at -10psi. You can set this with a simple hand held vacuum pump like they use for brake changes.
Also check your Crank Case Ventilation lines. They will crack right around 70-90k. They also have a special check valve in them that is known to go bad too, if this happens boost pressure will leak into the crankcase.
This alone will solve most under-boost codes. Then go on to the pressure converters, diverter valves, etc. if the codes still occur.
