      01-20-2021, 11:23 AM   #1
j1thu
j1thu's Avatar
Drives: BMW 6 Series Gran Coupe
2017 BMW 340i  [0.00]
Oil filter housing with heat exchanger leaking
Hi,
I'm after a bit of advise please...
I purchased an E71 X6 with the N57 engine, just before Christmas.
As I do with all the cars that I buy, I give the car a service. I dropped the car off at my local "BMW Specialist" two days before Christmas day for them to carry out the service.
They phoned me at 1545 that day and said that there was a problem.
Upon removing the oil filter cap, the end of the shaft of the cap had snapped off. The car couldn't be driven and I had to wait till the day after boxing day.
Once the work was completed, I collected my car and the owner said how immaculate the car was both inside and out. No oil leaks.
Fast forward to today and I notice rainbow colours on the floor next to the car.
Quick look underneath and I find oil on the underside of the under tray.
I took the car back to the garage and they said that the oil filter housing with heat exchanger is leaking and costs over £500 to replace.
Am I being done over or is this genuine?
Any advice appreciated.
Thanks
      01-20-2021, 01:42 PM   #2
jaitoon
Drives: 2012 BMW X6 50i
You didnt say how many miles on your odometer, but i dont think they are taking you for a ride. If the N57s are anything like the N63s (8 cyclinder), if they are not well maintained, they will suffer oil and coolant leaks. Gaskets are poorly made on these vehicles, and in the case of the N63 with the valley shaped engines, they serve as a heat trap, cooking rubber hoses and all those plastic components. So to answer your question 2013 model x6, I think its genuine.
      01-21-2021, 12:25 AM   #3
j1thu
j1thu's Avatar
The mileage is 78k. Perhaps you're right.
      01-24-2021, 06:06 PM   #4
jaitoon
at 78K, and the shaft of the cap snapping off like that, very possible you may have some heat soaking issues going on. Watch out for additional leaks from PCV valve and head cover gasket leaks.
