      01-17-2021, 12:19 PM   #1
IRG006
Drives: F430 and a white Testarossa
2010 BMW X6M Low Pressure Fuel Sensor
Vehicle being diagnosed 2010 BMW X6M.
4.4l v8 (s63) First production year
Issue: Car starts idles for a while and cuts fuel out until stalling.
Troubleshooting Workflow:
Towed to BMW of Vista
Diagnosed as low fuel pressure sensor error estimated repair quote $950.00USD
Repairs declined vehicle towed to a private garage
BMW ISTA Diagnostics: See attached DOCs
Fuel low-pressure sensor fitted (old) SENSATA pn: 13537614317
Workflow recommendation to change sensor to (new) BOSCH pn: 13537622231
Note: Changing from old to new due to fitment of the BOSCH housing a new and updated fuel rail is required pn:13537622850 (new with sensor)
Old fuel rail with SENSATA sensor pn: 13538649966
FCP EURO retro fit kit without fuel rail upgrade SKU: KIT-13537622231KT
Orderd one FCP EURO kit
Installed retrofit kit.
Cleared all codes with ISTA/D no stored faults
Car test Driven for 3 mile loop
Car passes test drive
The vehicle is parked and left idle for 10 minutes after test drive
Vehicle show fuel pump error (infotainment) and stall out.
Retro fit kit removed and the sensor is replaced with a brand new SENSTA sensor old disregarding the upgrading of fuel rail.
Car turns on and idles at 750rpm (normal)
Car fails test drive goes into limp mode under hard acceleration in M mode limps last mile to garage
The vehicle is parked restarted and error codes cleared with ISTA/D
Old Sensor left in place due to the nature of not replacing the fuel rail ordered 1 HPFP (vehicle has 2)
New HPFP is installed
Vehicle cooled and HPFP swapped to the opposite bank
Old HPFP reinstalled.
FACT: Low Fuel Pressure sensor is part of a mechanical test routine and is not part of FAULT elimination via ISTA/D
Theory: issue lies within EKPS module or low-pressure fuel pump location double gas tank under rear seats.
Recommended repair: throw money at the problem
ISTA
View post on imgur.com
ISTA system version: 4.27.22.22497
VIN: 5YMGZ0C5XALK13668
Int.lev.works: E070-09-09-522
Mileage: 82093 km
Code
002A28002B12006296
Description
Fuel low pressure, operating rangeCylinder injection cutoutEKPS: No pump speed signal
Data version: R4.27.22
Vehicle: X'/E71/SC/ -US/LL/2009/10 Int.lev.(cur.): E070-09-09-522
/S63,-/AUTO/
Programming data: 4.27.20
Int.lev.(tar.):-
Mileage
820888208882088
Existent
yesyes
File Type: pdf 20210117_074446_Operations_report_VIN7-LK13668.pdf (104.8 KB, 776 views)
      06-18-2021, 11:37 PM   #2
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
Was this ever resolved?
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      06-19-2021, 08:18 AM   #3
IRG006
Yes it was. Low pressure fuel pump failed. There is a service bulletin that extends warranty to -0 years on it. The high pressure fuel rail should be upgraded to Bosch due to the revised sensor.
      06-19-2021, 10:57 AM   #4
1er_vert
Did you code the new EKPS yourself?
      06-19-2021, 10:59 AM   #5
IRG006
So I can do that but I never installed the née EKPS as the old one I salvaged just had to rewire the harness. Which BMW sells a kit for you can find it on ECS website.
