12-29-2020, 10:06 AM | #1 |
Rep 192
Hello everyone, I am \\\M owner (E71 M). I'm usually around seeing what's going on in the community, appreciating and reading posts.
I would like some advice and opinions, my car will be paid off within the next month or 2 and I am planning a Course of Action in terms completing these repairs from most important to least important. The fuel injectors are from index 11-12 (I did do the SB but not all were changed) All ideas and recommendations are welcomed. Thank you. |
01-01-2021, 11:08 AM | #2 |
Rep 1,564
Injectors and coils would be wise, use Eldor coils from fcp euro if you want the best, do NOT use Bosch coils made in Slovenia.
Do all of you're crankcase Hoses, they will all fail due excessive heat trapped I'm engine compartment. Ask him why turbos need to be replaced. That is a massive expense, looking at around 4k for it alone. |
01-02-2021, 07:43 PM | #3 | ||
Rep 192
I am undergoing an oil consumption test, because I had a major coolant Issue which leads me to that hypothesis. I can be wrong, at the same time all the other reasons don't apply to me. I don't have no long trails of smoke etc... I will take a look into what you suggested. I agree with your COA as well. Thank you for taking time to help out. Happy New Years, My Brother! |
01-07-2021, 03:00 AM | #4 |
BMW fanatic
Rep 4
if your turbo leaking oil try aftermarket chinese cartridges ebay item number 224136419947
replace not so heavy. cartridges cost $150 pair. DIY about 3 hours. depending lower clamp bolt where looking. better to remove generator. but I did without removing generator. when assembling back pay attention to where looking exhaust and intake sides. if you turn/install wrong - pipes does not stand where they supposed to stay. |
01-15-2021, 12:41 AM | #5 |
Rep 192
Oil consumption Test was performed and it was said my valve stem seals are bad.
In the process of getting the situation rectified. Hopefully it works out in my favor. (Fingers crossed) |
01-15-2021, 06:45 AM | #6 |
Railside Performance
48
Rep 331
Drives: E92 M3 R8 V10 Q5
Garage List 2010 Ducati Streetf ... [7.00]
2017 Q5 [0.00] 2017 BMW R NineT Racer [5.00] 2010 Audi R8 V10 Ma ... [0.00] 2008 M3 [10.00] |
I would do the operational parts such as M Q R S. If the shocks are not leaking and feel good then wait.
E92 M3 Manual
R8 V10 Manual / Audi Q5 Ducati Streetfighter 1098 / BMW R NineT Racer Ducati Monster 796 / Ducati Bronco 1964 Railside Performance |
