07-16-2008, 05:17 PM | #1 |
Rep 392
Snow Tires on 20" Wheels
Hi Guys,
I did some research today and I thought I'd share my findings with you. Since I only intend to drive the X6 in the winter (and it snows here in Toronto) and I don't like how the way the X6 looks with the smaller wheels, I needed to find a snow tire that fits on the 20" wheels that come with the X6's Sports Package. There is no direct fit Snow Tire for the X6 20" wheels, so I found a set of snow tires that are narrower but will still fit the X6's 20" wheels. The overall diameter front & rear both get higher (it is good when snow tires have higher sidewalls for more grip) but since they both get higher by the same amount, it won't mess up the AWD system. The tire is also V-rated (149mph) which is good enough for the X6 50i which is top-speed limited. The ONLY tires with sizes suitable for the X6's 20" wheels are as follows: Pirelli Scorpion Ice & Snow 265/45VR20 XL - Front (Fits a 10" rim which is the X6's Front Rim Width) 295/40VR20 XL - Back (Fits a 11" rim which is the X6's Rear Rim Width) The whole set can be had for about $1,044 from Tirerack.com which is a great deal. So if anyone is looking for snow tires on their 20" X6 wheels, these are the ONLY ones right now! - KJ |
07-16-2008, 05:27 PM | #2 | |
Rep 1,754
Here are some info's on the style 275: X6 21" STAR SPOKE 275 Dunlop SP Sport Maxx 285/35 R 21 W, Front 325/30 R 21 W, Rear MSRP: $5,800 The MSRP is in CAD.
2009 750i individual | Citrin Black Metallic | Platinum Merino Extended Leather | BMW Individual Composition Package (includes Sport Package) | Dynamic Handling Package | Multimedia Package | Technology Package | Executive Package
http://www.7post.com/forums/showthread.php?t=234432 |
07-17-2008, 06:53 AM | #3 | |
Rep 7,034
07-17-2008, 07:55 AM | #4 | |
Rep 728
07-17-2008, 09:02 AM | #5 |
An Englishman in Chicago......
Rep 128
Thanks KJ - great info - I thought I was going to have to buy a new rim and tire package for the Chicago winter. This should save me a few $$$.
Cheers, Anteater. |
07-17-2008, 09:46 AM | #6 | |
Rep 392
Turns out there is ONE snow tire that will fit AND it's priced very well too!!! - KJ |
09-18-2008, 10:19 PM | #7 |
Rep 1,754
Just came across this info while doing some research for winter tires for my wife's car:
Bridgestone Blizzak LM-25 4X4 with UNI-T tires that should fit the Style 259 rims: 255/40RF20 97V Fits 8.5-10.0 rims 285/35RF20 100V Fits 9.5-11.0 rims For reference, here are the specs on the original tires: Star Spoke alloy wheels – Style 259 20 x 10.0 front, 275/40R-20 20 x 11.0 rear, 315/35R-20 run-flat all-season tires The advantage of these tires in comparison to those that KJ posted above, is that the aspect ratios (side wall height) are the same as those of the high performance summer run-flat tires! Here is a link to the actual overview of all available tires in the Blizzak LM25 4X4 range: http://www.bridgestonetire.com/tires...roduct_ID=1117 Here is a link to the PDF version of that page: http://productcat.bridgestonetire.co.../pp_900109.pdf
http://www.7post.com/forums/showthread.php?t=234432 Last edited by xDrive50i; 09-18-2008 at 11:04 PM.. |
09-19-2008, 12:58 AM | #8 | |
Rep 392
Stock Sidewalls: 275/40R-20 = 110mm Front 315/35R-20 = 110mm Back Yours Sidewalls: 255/40RF20 = 102mm Front (8mm too short) 285/35RF20 = 100mm Back (10mm too short) My Sidewalls: 265/45VR20 = 119mm (9mm too tall) 295/40VR20 = 118mm (8mm too tall) That being said, the much more important measurement is OVERALL DIAMETER. Although you can calculate the height of the sidewall using the specs on the tire, sometimes they aren't totally accurate. That's why overall diameter is the best measurement as it eliminates the manufacturer to manufacturer variances. Stock Diameter (SP Sport Maxx RunOnFlat): 275/40R-20 = 29" Front 315/35R-20 = 29" Back Yours Sidewalls: 255/40RF20 = 27.9" Front (1.1" too short) 285/35RF20 = 27.9" Back (1.1" too short) My Sidewalls: 265/45VR20 = 29.4" (0.4" too tall) 295/40VR20 = 29.3" (0.3" too tall) It is better to have taller sidewalls for winter tires as the rubber sidewall grips snow better than say an aluminum rim. Although a narrower tire is normally better for the snow, having a tire that's too narrow will mean that the tire is "stretched" onto the rim more meaning the sidewall won't be as flexible, which leads to less grip as the tire can't conform to the road as well. That being said, the Blizzak is another possible choice for a winter tire. All else being equal, I would choose a Bridgestone tire over a Pirelli tire. However, in this case, the Pirelli's are much closer in overall diamter than the Bridgestones. - KJ P.S. When I checked today, I noticed that Pirelli now makes a front tire the EXACT same size as the stock front. However, if you were to go with that tire, the front tire would be shorter than the back tire leading to potential issues with the AWD system's differential. |
09-19-2008, 02:16 AM | #9 | |
Rep 7,034
09-19-2008, 08:56 AM | #10 |
Rep 38
I've heard that the RFT are not recommended for removal and reuse. So can I still remove my summer RFT and use the rims for the winters?
2008 X6 xDrive 3.5i Apline White with Cheateau Nevada Interior.
09-19-2008, 09:04 AM | #11 |
Rep 256
My experience is that Blizzaks are great for the first couple of winters but they 'fade' quickly after that. The Pirellis do not have the same ultimate snow grip as Blizzaks but they are better in highway conditions (packed snow and ice) and tend to keep their performance longer. Just about every BMW and Mercedes dealer around here recommends them.
I just ordered a set of 20-inch OZ Canyon wheels, Pirelli Scorpion tires, and TPM for my new Mmm... (you know.... not X6!) and the price from a local speed shop was the same almost to the penny as Tire Rack's: Cdn$4,150 including all taxes vs US$3,995 including shipping and Cdn taxes. Nothing against Tire Rack, I love 'em, but if I can buy locally where I will obviously get better service if anything goes wrong, then I will. You guys in TO may want to shop around a little. |
09-19-2008, 09:21 AM | #12 | |
Rep 1,754
One other thing I noticed this morning is that the Blizzak tires do NOT seem to be RFTs! I think I'm just going to get a complete new set of wheels for winter driving anyway.
09-19-2008, 03:16 PM | #13 | |
Rep 392
The best places to go to are the places that mount tires on expensive luxury wheels on a regular basis. They're used to babying wheels. - KJ |
09-19-2008, 04:25 PM | #14 |
Rep 256
No way I would have tires mounted and demounted twice a year! Apart from the cost and inconvenience, you risk damaging either the wheel or the tire every spring and fall. Much better to buy a set of winter wheels.
09-19-2008, 05:29 PM | #15 | |
Rep 7,034
Only new set of alloys and winter tyres! |
09-19-2008, 06:11 PM | #16 |
Rep 392
It is more inconvenient, but in the end, you do save a fair bit of money.
Mounting tires onto rims only costs $80 each time. You do it once in spring and once before snowfall, so $160/year. If you lease the car and drive it only 3-years, the total cost would be less than $500 for labour. The tires would cost about $1,200 for the set so $1,700 total for 3-years of use. Which is substantially less than say $4,150 for a winter "rim and tire set". You get to drive on the "nice wheels" all year round instead of having a "winter set" that's not as nice. It's definitely not an option for everyone. But if you want to save some cash and drive on the "nice wheels" all year round, then it's a better option for some. If you buy winter rims and tires, you can spend an hour to mount them yourself (make sure to invest in a torque wrench), or you could pay someone $40 to do it. In the end, you still fork out cash for labour. That being said, paying $80 to have someone mount the tires onto the rims is only $40 more. Either way, you gotta leave your car at a shop. You're not doing the work, so the inconvenience isn't that great. It's more of a pain for the shop than it is for you. - KJ P.S. I would rather get the dealer to swap the stock tires for snow tires on the stock 19" wheels and then spend some money on aftermarket 20" or 21" wheels with performance tires. That way you get a fancy set of 20's or 21's. I'd rather spend money on aftermarket wheels for the summer, instead of spending money on wheels just for winter. |
09-21-2008, 10:51 AM | #18 |
Rep 128
Anyone have any thoughts about just buying a set of stock-comparable 19" rims and winter tires together and switching them out from the summer 20"s?
I've got the 20" 214's currently fitted but it's relatively easy to buy a set of 255/50-19 tires and aftermarket rims that match the 'non-sports package' standard 35i setup than new 20" rims and tires for front/back separately (due to width differences). Interestingly, the stock 19" BMW package has 9" wide rims - most aftermarket 19" rims seem to come in either 8.5" or 9.5" width. Anyone know if this is likely to be an issue? It's MUCH cheaper to buy a set of anfermarket 19" rims and tires to get to the same wheel circumference as stock 19" (even including new TPMS fittings) than buying the winter wheel packages from the dealer. Thoughts? Cheers, Anteater. |
09-21-2008, 01:37 PM | #20 |
Rep 128
TireRack are offering an 18" winter tire & wheel package alternative for the X6:
18X8 Sport Edition TK1 Bright Silver Paint for 2008 BMW X6 xDrive35i In Stock 012345678 $159.00 each 235/60R18 Bridgestone Blizzak DM-Z3 Blackwall for 2008 BMW X6 xDrive35i In Stock 012345678 $134.00 each 433MHZ TIRE PRESSURE SENSOR for 2008 BMW X6 xDrive35i Not Available 012345678 $42.00 each REQUIRED VALVE for 2008 BMW X6 xDrive35i In Stock 012345678 $8.00 each Hunter Road Force™ Mounting and Balancing FREE! Total: $1,372.00 + Tax Sounds pretty good to me other than the TPMS is not currently available.... may be able to find an alternative rim however... Cheers, Anteater. |
12-10-2008, 01:52 PM | #22 | |
Rep 6
