03-19-2014, 01:45 PM | #1 |
Bebeqq1231
Rep 44
Please help.. X6M hesitate after sitting for hours
Please help! Does anyone know the reason why my 2011 X5M hesitate to starting up, when it sit after a period of time. recently i have new Valve cover Gasket and Spark Plugs put in. Before takes 1 second to start now might takes 2-3 second. Also my rear view camera flicking and reverse. Anyway way to fix the issue? Thank you!
03-19-2014, 04:15 PM | #5 |
Rep 51
I believe the old injectors were labeled #8. It is now #11 so as you can see they have continue to update them. I'm not sure of the cost but I am sure they are in the thousands. Is your car still under warranty since it's a 2011?
03-19-2014, 05:28 PM | #7 |
Rep 1,391
One final test on injectors, on freeway put it on sport, down shift a couple of gears so at freeway speed you are running 4-5k RPM do this for maybe 5-minutes (in sport it won't up-shift so it'll hold the RPM at tha range).
IF you see CEL come in and go, yes you have borderline injectors. At higher RPM they need to ope/close at higher frequency. Hard start after cooling down only (w/o the above), is potential problems with low-pressure fuel pump or battery is weak. |
03-19-2014, 06:24 PM | #8 | |
Rep 508
03-19-2014, 07:11 PM | #9 | |
2020 Mineral White 30d MSport
523
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Due to poor gasoline down here, my car takes a couple of seconds to start, mostly when engine is hot, first morning start always is inmediate
03-19-2014, 07:13 PM | #10 | |
523
Rep 2,146
If your answer is yes, how long it stays until gets normal? My car started to have this problems, and finished changing all injectors after the problem got very bad
03-19-2014, 07:18 PM | #11 |
Bebeqq1231
Rep 44
Thank you all for the helpful information. Also hesitate means that it takes time to start up the car. maybe 3-5 second after crank. But once it's start, it's perfectly fine and smooth
03-19-2014, 07:20 PM | #12 |
Rep 51
^ I had a brand new battery put in and I still had a hard time starting up.
It could very well be a low pressure fuel pump but I don't know the symptoms for it since I haven't had mines replaced. As HPIA4v2 said you should do the test. I'm only going by what I've experienced. |
04-02-2014, 06:22 PM | #13 |
Bebeqq1231
Rep 44
Just purchase 8 new injector along with the injector seal. Does anyone know how much it cost for a shop to do the job? Is there anyway i can do it myself? Does anyone has the procedure? Thank you!
04-03-2014, 09:12 AM | #14 |
Rep 1,391
You need to figure out on how to get to the injectors but this instruction is a good start (I believe the N54 BMW uses the same exact injectors).
http://www.n54tech.com/forums/showthread.php?t=15140 GL |
