      01-02-2015, 09:26 AM   #1
x6Hawkeye
911 TTS Cab
x6Hawkeye's Avatar
Drives: '17 Porsche 911 Turbo S Cabrio
Just dropped my 2013 X6 50i off at dealership to have battery tested and they indicated a major engine recall just announced at dealers. They've not yet sent out notices, but sounds extensive. I'm the first one they've even looked at in this dealership as I just happened to be there today.
They are keeping it all day for tests and indicated recall is in (2) parts. First part is a pretty significant amount of parts they have to replace on engine. They'll then test, if fail then they said next modification could require pulling engine out...yikes!
I don't have a lot of detail, will post if if learn more. Interested to see if others have heard anything as well.
Correction: I believe this may be "N63", not "N83" engine... It's the 8 cylinder.
      01-02-2015, 09:36 AM   #2
samson
Drives: 2011 X5 5.0, black on tan.
It is for the N63. I was at the dealership on Wednesday and my SA told me about it. Has to do with broken timing chains. She said something about the software they are using to analyze and diagnose was not functioning properly and they might have to pull the engines. Was pretty unclear about it but it does not sound like a quick fix. There are some other posts about it on various sites.
Mine is going in on Tuesday.
2011 x5 5.0, black on tan - active duty
2006 e90 mystic blue - retired
2000 323it silver - retired
1996 325 convertible - retired
1989 535i - retired
      01-02-2015, 05:32 PM   #3
Frankkao14
Drives: 2012 BMW X6 50i
How did you guys find out about the recall?
I called the dealership and they said that there is no recall for my 2012 X6 50i...
      01-02-2015, 08:06 PM   #4
x6Hawkeye
911 TTS Cab
x6Hawkeye's Avatar
I took mine in for accelerated battery discharge and they told me the notice just came out. They've not "officially" announced it to owners yet, but wanted to test it for the recall since it would be there all day regardless.
      01-02-2015, 08:07 PM   #5
x6Hawkeye
911 TTS Cab
x6Hawkeye's Avatar
They mentioned replacing injectors and a pump (as well as other components) I believe. Not sure of the exact detail either, I'll see if I can learn more.
      01-04-2015, 05:37 PM   #6
Jalndrs
Drives: 2015 F15 35i
I just dropped my X5 off for the "increased battery discharge" issue now. What was the outcome and what was causing it? It has been a pain and today my heat was only working out of the defrost when on "auto".
      01-05-2015, 08:24 AM   #7
x6Hawkeye
911 TTS Cab
x6Hawkeye's Avatar
Jalndrs, no outcome yet. They told us Sat the battery and et all are fine (as they've told us on a prior visit), but they're diving deeper now. They said that a fuel pump is known to cause this so they're checking this. They also think it could be attributed to other recall items. I don't know full scope of what they're changing out - they said it was fine regarding timing but there are other items they're replacing.
      01-05-2015, 10:36 PM   #8
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
My dealer called it more of a "customer service campaign". He did note that on all of the N63 engines (including the N63tu) the battery is now a maintenance item and will be replaced automatically every second oil change provided the car is under warranty.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      01-05-2015, 11:10 PM   #9
x6Hawkeye
911 TTS Cab
x6Hawkeye's Avatar
Thanks Doug, good to know. I see we have similar taste in cars - nice looking Gran Coupe!
      01-07-2015, 11:50 AM   #10
Frankkao14
so I called the dealership again and they said that if you type ur VIN on Bmwusa.com/recall and if it doesnt show up yet…you have to wait until it says there is a recall for your vehicle….
Am I getting the right info? or can I just go in and schedule an appointment with the dealership?
      01-07-2015, 12:13 PM   #11
doug_999
doug_999's Avatar
2542
Thanks! Right back at you!
Per my dealer, it is not a recall. Maybe they just have not been informed yet? He did say that he was only aware of replacing 4 timing chains in the last 5 or so years. So he was not sure what the big deal was.
      01-07-2015, 06:50 PM   #12
x6Hawkeye
911 TTS Cab
x6Hawkeye's Avatar
My dealer called it a recall, but indicated only dealers new about it so far (announced to them last Wed?).
Was more than timing chains. They tested this and it was ok, but replaced other parts. I've not picked it up yet - I'll update the parts if it's in receipt (obviously BMW paid).
I did get a new battery to help the discharge issue (reason we brought it in to begin with).
