      12-02-2016, 09:00 AM   #1
madbim
madbim's Avatar
Drives: 08' E90 335xi
2013 35d nox code
Recently picked up a 35d, throwing the codes below. I searched and couldnt find much of anything regarding these codes. Where do I start?
  • DeNOx system efficiency: efficiency is to low in the range 1 code: 0042FC
  • DeNOx system efficiency efficiency at low code: 004D18
      12-04-2016, 06:45 AM   #2
ntailor
Drives: i5 M60, X7 M60i
I had that come on before. Dealer changed my nox sensors under warranty
      12-04-2016, 09:21 AM   #3
Kakalika
Kakalika's Avatar
Drives: 2014 X5 35d M Sport
Yep, NOX sensors, will trigger the check engine light.
RUN FLAT TIRES? NEIN DANKE!
      12-06-2016, 10:10 PM   #4
madbim
madbim's Avatar
I was in the dealership for disabling the combox, they noticed it had a recall on nox sensor. They completed the work and indicated it could be the source of the codes indicated, code hasn't come back since.
      12-08-2016, 07:38 PM   #5
ingenieur
ingenieur's Avatar
24
Drives: 2011 335d MSport
What exactly did they replace/repair?
What part numbers are on the invoice?
