      01-15-2016, 10:11 PM   #1
Qarban
Drives: E70 X5 and E70 X5M
X5M Engine Oil Level
My X5M got an oil change today from BMW of Austin, and soon after arriving home I checked the idrive screen for oil level and this is what it showed on the display. Is it OK if the oil level is not at the maximum level or it should have been topped off?
Picture below is from my wife's 3.0si X5 screen, last oil change was 2 months ago and the display shows the oil volume is at the maximum level and I don't remember it displaying below the max level since day one of ownership.
Thanks!
      01-15-2016, 11:23 PM   #2
KayTees
Tuned ///M Cars Only
KayTees's Avatar
Drives: '21 F87 M2C |'20 F97 X3MC
And this is why I do my own oil changes...
      01-15-2016, 11:25 PM   #3
protecon
*May contain nuts
protecon's Avatar
Australia
193
Drives: 2010 X5M MCB
Err oil level should never be at maximum or above. If it's reading maximum, how do you know if it's not overfull?
Too much oil will cause all sorts of problems, including being whipped by the crank during operation, causing the oil to become aerated and effectively losing the ability to pump it around the engine.
      01-16-2016, 05:15 AM   #4
Qarban
You mean the first picture is OK and the second one is not?
      01-16-2016, 05:41 AM   #5
protecon
*May contain nuts
protecon's Avatar
Australia
193
Hard to say without a physical dipstick.
If it's above minimum, I'd only worry about the quality of the oil.
Maximum is only there to prevent damage.
      01-16-2016, 08:01 AM   #6
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I don't know if it displays an oil level above maximum. If not, then there is no way to know if overfilled. On that case, I'd rather it showed just below maximum.
      01-16-2016, 12:02 PM   #7
Qarban
A member in this forum got a warning message for overfilled oil
      01-19-2016, 08:26 PM   #8
Qarban
Thanks!
Four days since oil change the oil volume now shows it is in maximum level
      01-20-2016, 10:35 AM   #9
ChiTownM
ChiTownM's Avatar
Drives: M and i BMWs
Has happened to me too, I wouldn't worry so much as long as it is not overfilled.
      01-20-2016, 12:43 PM   #10
Mnite_S63
Drives: 2013 F13 M6, 2010 X5M
I did my own oil change and the reading fluctuates from full to shy full. At one point I thought I needed to top it off but after driving 120 miles it registered Max.
I agree best leave it alone but keep an eye on it. If it continues to drop then a top off might be needed.
      01-28-2016, 03:05 PM   #11
Brooklyn e70
Brooklyn e70's Avatar
Drives: e70 msport
on my old e90 it has given me warning to add 1 quart of oil if it was low
