      04-23-2015, 04:24 PM   #1
Dr_Dooms
Drives: X1 M-sport
Unhappy New e70 owner HELP with P0012 code
I usually don't post on forums, mainly browsw but I have been stumped. Ive owned an e30, e36, e46, e92, e85, and an e86.
I was previously an automotive mechanic and now I am a jet engine technician, so I have a large amount of knowledge when it comes to cars. but this time I've been stumped and could use some help!
So I picked up my 2010 x5 Msport at about 6k under blue book because it was at a dodge dealership and it had a check engine light.
so I get these two codes. p0012 and p1434
I've been doing a ton of research on this problem.
I've seen that it can be an intake cam sensor. so i order two of them and replace both of them. no luck
I saw someone have the incorrect oil which caused the vanos to freak out.
I got oem bmw oil and filter from ecs. no luck
Next step was to replace the vanos solenoids. I ordered two of them from getbmwparts.com. installed them. surprise surprise. no luck..
When I clear the code, start the car and drive, no MIL. but as soon as I shut the car off and restart it, the light comes right back on with both codes
I have ran out of solutions at this point.
I am reading online that the p1434 code is for the secondary air pump, i don't believe that the air pump would be causing a p0012 code, so i haven't bothered replacing that yet.
It runs fine and drives fine as well.
does anyone have any suggestions?
Thanks in advance for any help!
      04-23-2015, 06:39 PM   #2
retusn
retusn's Avatar
Drives: 2013 X5M
I was reading on another forum where someone had the same problem on a 530i. They replaced the sensors and the code came back. They took it in for repairs and the shop replaced the oil fill cap. They said there were some components broken inside the cap and it messed with the oil pressure. Don't know how accurate that is but stranger things have happened.
One other note, did this have the engine campaign done on the engine? You might check with a BMW dealer and see if it is done or not. Could be BMW will fix it with the N63 campaign.
2013 E70 X5M
2011 E92 M3 traded in, 2009 CTSV LEMON, 2008 Z06 Lemon Law, 2007 Z06 Dealer butcher, 2004 Z06 (Sold)
1996 GrandSport (sold), 1996 Impala SS (Sold)
      04-24-2015, 06:11 AM   #3
Dr_Dooms
Drives: X1 M-sport
I actually just did a search and there is a recall involving the vanos system, they said a bolt comes loose and causes vanos issues, I'll call today! Thanks for the idea!
      04-24-2015, 04:27 PM   #4
Dr_Dooms
Drives: X1 M-sport
bmw said there is no recalls for vehicle
      04-25-2015, 06:44 AM   #5
retusn
retusn's Avatar
Drives: 2013 X5M
Do you have the X5 with the V8 4.4? If you have the N63 engine there is a service bulletin campaign for fixing different potential problems with the vehicle. There is a thread on it here.
2013 E70 X5M
      04-25-2015, 02:15 PM   #6
Dr_Dooms
Drives: X1 M-sport
No, it's an xdrive30i
So it's an n52
      04-25-2015, 04:25 PM   #7
lanbrown
Drives: BMW X5
The OP never said initially what engine they had, but the 2010 didn't have the N63 engine.
      01-22-2016, 08:44 AM   #8
ncviz
Drives: 2011 BMW M3 E90
Did you ever figure this out? I've got a P0012 code only. I was thinking cam sensors or vanos solenoids. Let me know what you ended up finding out.
      01-27-2016, 01:37 PM   #9
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
I'm also getting the P0012 and I have read to check or clean the vanos sensors.
I haven't done that because I haven't researched where they are located.
2011 M3 Coupe,Jerez Black,DCT,EDC,DSC
2010 X5 30i Black
      02-17-2016, 09:29 AM   #10
Rbembas_M3
Rbembas_M3's Avatar
Drives: BMW 2011 M3
2011 BMW M3  [0.00]
I replaced both vanos solenoids, cleared the code, started the engine, no engine light. When I turned off the engine and started it back up, boom engine light come on. Now I'm thinking it's the vanos seals. I can tell you one thing the engine sounds like a diesel with the old solenoids, with the new solenoids it sounds great and the engine idles quietly.
2010 X5 30i Black
      11-06-2016, 08:13 PM   #11
X5M_Midwest
Drives: 2002 E46 M3 Vert
im now having the P0012 code on my 2010 x5m. hope its nothing to crazy. bringing it in tomorrow.
      11-17-2016, 10:31 AM   #12
belarus27
Drives: E550
anyone can share what the problem is/was? who got it fixed?
