      08-16-2020, 08:53 PM   #1
eDubz
Drives: 2012 X5M
Downpipes CEL Question
Hey guys, I'm thinking about doing the VSRF downpipes but I have some newb questions...
I have the Velos tune and I know it tunes out the CEL, but I can't pass emissions with the Velos tune installed (the O2 system shows as "not ready" so it consistently fails).
So I need to figure out a way to have no CEL with the downpipes and a stock tune.
I'm assuming I should use a spark plug O2 non-fouler on the second O2 sensor, but I'm looking for someone to confirm.
If so, can you send me a link to the non-fouler you used? Or will any non-fouler work?
Appreciate any insight!
2012 X5M /// Velos Stage 2 /// xHP Stage 3 TCU tune /// Sprint Booster
2013 X3 35i M-Sport
      08-16-2020, 09:46 PM   #2
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
Are you 100% on the monitor situation with the tune? I've had two different Velos tuned X5Ms pass NY inspections (which require OBDII readiness, perhaps with one allowance for a non-critical monitor being off-line). My only challenge along those lines was when I did the first install, I let the shop skip doing the O2 sensors correctly. It ran poorly and with a persistent CEL until we had everything connected properly. Ran great and passed inspection after that.
'01 740i Sport; ‘06 Z4M Original owner, no mods
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car
Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31
      08-17-2020, 06:35 AM   #3
eDubz
Drives: 2012 X5M
Yes, 100% sure. I had a long battle with this...failed emissions about 8 times, dealership couldn't figure it out, etc.
Finally had the thought that it could've been the tune and flashed it back to stock and it passed right away.
Here's a thread on it -
Failed Emissions https://www.xbimmers.com/forums/show....php?t=1639489
2013 X3 35i M-Sport
      08-17-2020, 10:58 AM   #4
pearlpower
Drives: 2013 328i
I need to reinstall my downpipes shortly as I have smog coming up within a month. I will also flash back to stock. I get a constant CEL, even with extenders, nonfoulers in the plugs.
      08-17-2020, 05:24 PM   #5
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Are you sure your Velos tune has the downstream cat sensors deleted? Because i have Velos and mine are deleted and show ready.
      08-17-2020, 10:58 PM   #6
mhkm
The Doctor
mhkm's Avatar
14
Drives: 2007 E92 335i; 2013 E70 X5M
I also have the velos tune and catless downpipes and never had a CEL.
2007 335i: Evolve tune, AR Catless DP, VK FMIC, Vorsteiner lip, VRS CSI bootlid, Lux V3, RD strut bar, P3 Boost guage, PSW, BMW Performance Power Kit, Injen intake - TOTALLED by son
2013 X5M: VRS lip, Velos Tune, Catless DP, Dome hood, electric trailer hitch, performance alcantera SW.
      08-18-2020, 08:38 AM   #7
eDubz
Drives: 2012 X5M
Yes, they tune out the CEL, but have you tried to pass emissions with the tune on?
When the Velos tune is applied, I fail emissions due to the cat and O2 systems showing as "not complete".
I'm sure if I add the downpipes, I won't have a CEL, but will still fail emissions due to those systems showing "not complete".
So the question is - why do those systems show as "not complete" with the Velos tune installed, but immediately show as "ready" when I install the stock tune?
I reached out to Velos to get their thoughts.
2013 X3 35i M-Sport
      08-18-2020, 10:09 AM   #8
eDubz
Drives: 2012 X5M
To reiterate the root of my question...is it possible to have a stock tune, no CEL, and catless downpipes?
That would solve my problem because I could just flash back to stock when I need emissions tested (like I do now).
2013 X3 35i M-Sport
      08-18-2020, 10:58 AM   #9
ryansbmw
Drives: 2013 X5 35i M-Sport, 2010 535x
You can try the spark plug defouler but its no guarantee it will work.
https://www.fabspeed.com/universal-o...verter-single/
Before companies built spacers with catalytic material placed inside, I built my own for my E39 ( had headers and euro sport cats installed) and it worked. I passed inspection here in NJ without issue.
VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
Need coding or modules reset? PM me
      08-18-2020, 10:58 AM   #10
Sophisticated Redneck
Drives: 2012 BMW X5 50i
I don't think the non-foulers work, and tried then and still got a CEL. I haven't tried these yet but this is probably the only way to do it if you live in a state that requires every monitor to be active:
https://www.magnumtuning.com/en/deta...ect-box-anchor
      08-22-2020, 11:42 AM   #11
Dawgz
2022 M4 Comp Xdrive
1016
I have the Velos tune as well and I just ran the emissions check and my monitor shows INC.
This will surely fail if I went to get it checked.
      08-23-2020, 09:17 PM   #12
Dawgz
2022 M4 Comp Xdrive
1016
This does seem like the only way.
      08-23-2020, 09:23 PM   #13
eDubz
Drives: 2012 X5M
Carlos from Velos called me yesterday (on a Saturday, always great service). He suggested 200 cell catted downpipes.
I'll probably just end up doing the Megan exhaust for some added sound.
I realize it won't give me the performance upgrade I'm looking for from the downpipes, but it is what it is.
2013 X3 35i M-Sport
      08-23-2020, 09:47 PM   #14
Dawgz
2022 M4 Comp Xdrive
1016
You'll still need a different tune file tho right? One that doesn't delete the post Cat sensors
      08-23-2020, 10:03 PM   #15
eDubz
Drives: 2012 X5M
No because you can just flash it back to stock and pass emissions with a 200 cell cat. Then flash it back to the tune after you pass emissions.
2013 X3 35i M-Sport
      09-18-2020, 03:13 PM   #16
Dawgz
2022 M4 Comp Xdrive
1016
Which non-foulers did you try?
