      08-13-2020, 10:39 PM   #1
Koko M3
Drives: 4door m3
What tune are you running on your x5m
I wanted to know what tune all you x5m owners are running and how you like it.
      08-14-2020, 07:20 PM   #2
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Velos stage 2+
      08-15-2020, 11:17 PM   #3
Koko M3
Drives: 4door m3
Originally Posted by Dawgz View Post
Velos stage 2+
I really wanna see how a velos tune x5m since alot of ppl are running that tune on the car. i wonder how it will do with a dme tuned x5m stage 2+
      08-16-2020, 12:13 PM   #4
SkypirateX
SkypirateX's Avatar
45
Drives: 2012 X5M
BPM
Great customer support, reliable, no drama, no issues, not outsourced.
E70 X5M
      08-19-2020, 10:40 AM   #5
hunter_509
Drives: 2010 X5 M
I just had mine tuned by a local guy, shop is called RCP tuning. very satisfied, definitely woke the car up however now i seem to be losing power gradually. Doubt it has anything to do with the tune though.
      08-19-2020, 10:59 AM   #6
Koko M3
Drives: 4door m3
Definitely not the tune . do spark plugs and smoke test it see if there is any leak
      08-19-2020, 11:55 AM   #7
hunter_509
Drives: 2010 X5 M
yeah i am doing spark plugs this week. at 130k and not a whole lot of maintenance records, i probably should have done them off the bat. I plan the step colder plugs from NGK, probably gonna do BMC air filters at the same time.
      08-19-2020, 12:15 PM   #8
Koko M3
Drives: 4door m3
Yea i change my plug 2 Times a year since my car runs e85 and and ms109
      08-19-2020, 12:44 PM   #9
hunter_509
Drives: 2010 X5 M
What else do you have done to it? have you tracked it at all to see what it does in the 1/4?
      08-19-2020, 08:07 PM   #10
Koko M3
Drives: 4door m3
Dp exhaust upgraded thermostat oil cooler valve xhp trans tune dme tuned custom file to run all different race gas without changing files.
m5james431.00
      08-19-2020, 09:27 PM   #11
Autobacs
Autobacs's Avatar
Drives: 2019 BMW X6M
so are you talking about an X5M?
2019 BMW X6M
2013 Lexus RX450H
2010 Nissan GTR AMS Omega 14
m5james431.00
      08-19-2020, 09:42 PM   #12
Koko M3
Drives: 4door m3
Yes
      08-19-2020, 09:51 PM   #13
Autobacs
Autobacs's Avatar
DUDMD Tuning stage 1. Relatively conservative but definitely noticeable. With the age of the platform, I think stage 1 makes sense. about 10K miles now and no CEL or hiccups. Side note, gas mileage improved slightly also, that is when I'm not stomping on the gas.
2019 BMW X6M
2013 Lexus RX450H
      08-19-2020, 10:13 PM   #14
Koko M3
Drives: 4door m3
Yea once u stomp on it forget it. When i went to mpact i got 9mpg
      08-20-2020, 05:08 PM   #15
snowild
Drives: 2013 x5m
Currently running active autowerk stage 2. 611hp with crappy 91 gas
Did a few pulls today. crappy phone camera but you can zoom out and see the details. will be turning up the boost once i get a few thing dialed in. I highly recommend before a tune to check vacuum lines for leaks. Easiest way to know is doing a quick pull to 120ish with no fault. Also base on performance, the redesigned oem Mplugs are superior to the NGKs.
Frank Smith of tuning tech is the man.I highly recommend his costume tunes.
m5james431.00
      08-20-2020, 07:22 PM   #16
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
Running Velos Stage 2+. No complaints over the last ~15k miles.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
      08-20-2020, 08:43 PM   #17
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Nice pull! Do you know the part number on those plugs? I'm about to replace my NGK's
      08-20-2020, 08:47 PM   #18
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
Velos stage 2 tune for over 115k miles: 100k first owner, 15k me. No issues for me and none mentioned by the PO. It’s awesome.
Something expensive is going to “break” eventually, but only the timing chain guides (caught JUST early enough) have been a potentially catastrophic failure thus far.
'01 740i Sport; ‘06 Z4M Original owner, no mods
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car
Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31
      08-20-2020, 08:59 PM   #19
Koko M3
Drives: 4door m3
Nice ... frank smith hes good but dme made a file for me for max boost what ever these turbos can hold i really wonder what i make on dyno
      08-20-2020, 09:00 PM   #20
Koko M3
Drives: 4door m3
If anyone runs e85 i recommend getting the new ngk from Maximum PSI
      08-20-2020, 09:19 PM   #21
Dawgz
2022 M4 Comp Xdrive
1016
This is with stock turbos? If so that's pretty amazing.
Downpipes?
Also do you mean 531hp or 611? The picture shows max 531whp
611 shows as engine power...I assume that's crank.
      08-20-2020, 09:22 PM   #22
snowild
Drives: 2013 x5m
the part number for those Mplugs is 12120037581
