BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > E92 N54 Not hitting boost target
      03-08-2024, 10:36 AM   #1
n50whore
Drives: 2007 335i
Hello everyone I have a FBO N54 17Ts and I’m running MHD stage2+ but it seems I’m only hitting 7.2 PSI max on the data logs I’ve replaced vanos and I’m trying to figure out why it’s happening there’s no codes at all as well
DATALOGS:
      03-08-2024, 10:40 AM   #2
n50whore
Drives: 2007 335i
Here’s my WGDC
      03-12-2024, 04:47 AM   #3
wrevilo
Drives: 2010 E92 335i N55 6MT
Have you smoke tested for air leaks?
      03-12-2024, 05:01 PM   #4
whyzee125
Drives: Dinan stage 2 335i
Post a datazap link if you can, that will be much easier to get an idea of what's going on.
Upgraded turbos should not be run on an OTS map but that's kind of an unrelated issue.
How many miles on the turbos? Were you boosting fine on stock turbos?
      03-13-2024, 02:13 PM   #5
TheGoodTheBadTheUgly
Drives: 2011 E90 335i xDrive
This is the N55 section of the thread. Perhaps the N54 section would get you more accurate help and it is more active as well.
TOTALED | 2011 E90 335i xDrive - BMS Cold Air Intake - ETS Charge Pipe - ETS 7" FMIC - MHD Stage 2+ - GFB DV+ - PE Mod - VRSF Catless Downpipe - xDelete - xHP Stage 3
2015 E84 X1 35i M-Sport
