TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > N55 Misfiring after plug change
      11-12-2019, 05:03 PM   #1
Alturiak
Alturiak's Avatar
19
Drives: 2011 E92 335i
Hi guys,
Hoping you can help me track down whats going on here. I have a 2011 335 N55 with PS2, FBO, and all the other goodies to go along with it. At 95k I replaced coils and plugs with OEM coils, and NGK 97506 plugs gapped to 0.020". At around 104k the car started to get misfires under WOT in 4th gear and I figured it was just because the plugs were used/old now and I was running upwards of 25psi. So I decided to wait it out to 105k at my next oil change and do everything at once. During this I changed the oil, the spark plugs with again NGK 97506 gapped to 0.020", and cleaned all my air filters. I fire the car up and take it out for a rip, and boom 4th gear again at around 5500rpm it misfires. I check the codes, and it reads:
Codes thrown in 4th gear:
2F02 cylinder 4 misfire
2EFE Random/multiple cylinder misfire detected
2EE0 Combustion misfiring, several cylinders, fuel injection deactivation
2EED Combustion misfiring, cylinder 4: fuel injection deactivation
So I figure it must be a bad coil somehow on cylinder 4. Okay so I swap coils between 4 and 2, putting #4 in the #2 and putting the known good #2 coil in #4 spot, hoping the problem would move to cylinder 2 and identify the coil as bad. I take the car out for another rip and happens again. Same thing, car rips hard until ~5500rpm in 4th gear and misfires- throws exactly the same codes.
So I think damn maybe its the brand new plug, not impossible right? So I swap plugs from 4 to 2 and vice versa and take it out for a rip and get the same codes under the same condition again.
At this point I'm a bit at a loss as the only other things I can think of are fuel injector (which I think is unlikely) or something with the cylinder compression. Car has no vacuum leaks or anything like that.
Any help or suggestions would be greatly appreciated!
2011 E92 M-Sport BSM, Built N55 with 9.5:1 compression and forged internals, VAC Stage 3 Ported Head, custom tuned by Twisted Tuning, PR Coils, Pure Stage 2, Fuel It! Phoenix Race PI Manifold, StopTech BBK 380mm front 345mm rear, BBS CH-R Titanium, Dinan exhaust w/black tips, BMS Intake, DCT shifter retrofit, VRSF 3.5" downpipe, VRSF 7" HD IC, CSL CF trunk, 335is Rear Diffusor, Alpina B3 Trans Flash
      11-12-2019, 05:18 PM   #2
weehe126
Drives: 2017 340i
Check to make sure the wires on the #4 coil plug didn't push out, or that there isn't something causing it not to fully seat. Also check the ground and injector wiring.
      11-20-2019, 12:46 PM   #3
Alturiak
Alturiak's Avatar
19
So after checking with various other forums, it seems the fuel injector is likely the culprit. All wiring and connections were good, coil was not backed off of the plug or anything either. I'm going to install new injectors this weekend and I'll update after with the results
      11-20-2019, 03:26 PM   #4
tyson413
Drives: 2012 bmw 135I
Post a log at wot
      11-21-2019, 05:40 AM   #5
DiFFv1
DiFFv1's Avatar
Drives: 335i l 328xi l X5M
Question: Why gap 0.20 and not 0.22
"Proud Waitress At Gapplebees"
      11-21-2019, 10:18 AM   #6
bbnks2
Drives: 135i N55
Why gap them down at all, honestly...
OP, might be time to troubleshoot the injector. What does the cyl 4 plug look like?
      11-25-2019, 05:18 AM   #7
DiFFv1
DiFFv1's Avatar
Enlighten me on why you wouldn't gap down your spark plugs? Just asking i run a tuned 335i. i run 95570 NGKs. if i didnt gap them down i would have a firework of misfires
      11-25-2019, 07:41 AM   #8
bbnks2
Drives: 135i N55
You do you. People gap down plugs for no reason all the time... and plenty others can get away without gaping their plugs down at all.
      11-26-2019, 05:57 AM   #9
DiFFv1
DiFFv1's Avatar
Thanks smarty pants. i was just asking a question for info. preciate ya
      12-09-2019, 07:51 PM   #10
Alturiak
Alturiak's Avatar
19
Hey guys wanted to post an update. So I replaced all the fuel injectors (and coded the new values in INPA) and took the car out for a test drive. It appeared to still misfire on cylinder 4, which was pretty frustrating, then towards the end on my way back home I accelerated hard but not full WOT in second gear and the engine shut off on me. A strange red oil light came on the dash lcd screen and the half engine light came on.. checked the codes and it had a misfire in cylinder 1 and the motor would not start again. The codes read camshaft sensor both intake and exhaust circuit short to ground.
Took it to my local shop, Eurowurx in Burbank, and he told me the spark plug in cylinder 1 had the tip exploded off, and the motor was failing a compression test measuring 0psi across all cylinders. He didn't get much past that to tell me if its the head or the bottom end of the motor because he was too busy. The car is currently at Minicorsa in North Hollywood for further diagnosis, but sounds like either way the head needs to be pulled.
I'm even more stumped over this than the misfiring. What could cause this? Could the timing chain jumping do something like what has happened?
      12-10-2019, 09:14 AM   #11
weehe126
Drives: 2017 340i
Crank hub probably slipped and valves in all cylinders hit pistons causing no compression. Only way the chain would slip is if the hydrologic tensioner failed which I have never heard of. Easiest way to confirm timing slipped is to pull the valve cover and see if the cams are off.
      12-11-2019, 12:57 PM   #12
Alturiak
Alturiak's Avatar
19
The shop currently suspects spun crank hub as well. They're pulling the valve cover today to find out and I'll update within the next couple days.
      12-12-2019, 09:07 AM   #13
weehe126
Drives: 2017 340i
Hopefully timing is just off and valves didn't hit pistons. You can still have 0 compression with everything fine but timing off, so there is hope.
      01-13-2020, 03:16 PM   #14
Chris_Rav
Chris_Rav's Avatar
64
Drives: 2011 e92 LCI 335i xdrive 6MT
Alturiak Any updates on this? I have been trying to track down a very similar misfire issue for the last few months. WOT >5k rpm will yield a half engine light and the car needs to be restarted to get any power out of the engine again.
2011 AW / CR 6MT 335i Xdrive Coupe | JB4 Stage 2 | BMS Intake | Performance Spoiler | Powder Coated Red Linea Corse 818 | Blacked Out Roof | Wrapped Interior Trim
      02-18-2020, 03:13 PM   #15
carlosg1016
carlosg1016's Avatar
Drives: 2011 bmw 335i n55 e92
any updates on this im having problems with cyl4 misfiring
      02-18-2020, 03:55 PM   #16
TunafishE93
Drives: BMW 335i
Moral of story don't push car if its not running right... Who would of known..
      05-22-2021, 11:15 AM   #17
mhanson321
Drives: 08 328xi
Originally Posted by Alturiak View Post
Hi guys,
I just had the same issue 2011 335i xdrive changed plugs just as a preventive maintenance and felt like it had a slight hesitation. i followed all proper procedures... sure enough I get the cylinder number 4 misfire... I think coils. so I get a 6 pack and now I get multiple misfires on 1 and 3 and sometimes 4. put everything back in to what it was except cylinder number 5 plug because the gap was completely shut with no errors. and still have this stinking misfire. it'll drive but anything past 4th gear is almost enough to get yellow limp mode and shuts down cylinder 4 injector. I've tried clearing codes and idle is fine go through on the computer and shut down each injector individually and a rough idle happens as it should.... I'm so lost here and I never see any resolution on the forum just people dumping in parts..... grr help anyone?!?!?
      03-14-2024, 11:53 AM   #18
ghayes420
Drives: 2011 BMW 335i
Alturiak
Did you ever come up with a solution here for your misfires?
We are at a loss and could use some more advice. Thanks.
Tags
boost, coils, misfire, n55, plugs, ps2
