07-01-2010, 05:51 AM | #2 |
2nd to None!
42
Rep 296
Drives: M8 GC, M5 30Jahre, X6 50i
Oh Henry that is a camera for you to record the video ahead of you. No just joking, If I am not wrong that should be for the High-beam Assistant.
07-01-2010, 05:04 PM | #4 |
Rep 87
Ok, can someone tell me how the high beam assistant works because I can't seem to get mine working! I have ticked the box on the idrive, followed the instructions in the manual but nothing seems to happen. Am I missing something obvious?
Also, I ticked the box for the welcome light so anticipating the low beam to light up after the ignition is switched off, but again nothing - although the led's on the door handles do light up. Suggestions please... |
07-01-2010, 08:55 PM | #6 | |
Rep 683
"How do they come up with some of these gadgets?"
Is the driver too busy texting/figuring out idrive to change high to low beams? Does that sensor, the housing & wiring, weigh less then the switch in the column stalk? I hope so. The x6 is no light weight ! Does it make sense to switch to runflats, supposedly to reduce weight, then add back onto the curb weight stuff like self-closing door servo motors? Seems to me if someone can close the door to within reach of the latch to close itself, they could easily pick up the car & slam it to the door! If the airbags do not deploy, & the front windshield shatters b/c of road debris, that mirror & sensor housing is one heck of a projectile! So do we need a glass break sensor now.? Can we ever completely idiot proof a vehicle if it's driven by morons? Sorry, I'm beginning to sound like the guy on 60 minutes! Last edited by archwerks; 07-01-2010 at 09:10 PM.. |
07-01-2010, 11:23 PM | #7 |
Rep 81
Hi Henry, actually I am looking for such device so that I can record while driving. Nowadays many nasty drivers especially during the morning rush hours.
07-02-2010, 12:34 AM | #8 |
2nd to None!
42
Rep 296
There is in the market. I use Go Pro (HD Cam) which I had already fitted in my car. The othe type is for accident recording. In the event of a sudden brake the cam start recording.
07-02-2010, 12:39 AM | #9 | |
2nd to None!
42
Rep 296
07-02-2010, 02:43 AM | #10 |
Rep 81
Does the Go Pro also record when the park is parked? How much is it? Did you fit it yourself or you need someone to install it?
07-02-2010, 03:18 AM | #11 |
//M addicted
Rep 128
