      07-15-2014, 06:26 PM   #1
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
523
Drives: 2020 Mineral White 30d MSport
Increased Battery Discharge solution
UPDATE: This specific charger only works in 220-240V (had to return it because here we run on 110-120V), you can get the same one (no BMW logo) working on 110-120V in Amazon (CTEK (56-959) MUS 4.3 TEST&CHARGE 12V Battery Charger) for $95
"Increased Battery Discharge" on M cars.
just wanted to share with you a battery charger I bought today from my local BMW dealer (part # 61-43-2-334-068)
It charges (trickle 5.o Amps), also checks battery status, alternator status and checks startup (cranking)of the engine, seems like a nice gadget, hope it will solve my Increased Battery Discharge warning.
Check the pics video and pictures below:
      07-15-2014, 06:59 PM   #2
Tailwinds
Drives: X6m
Thanks for sharing. Cost?
      07-15-2014, 07:08 PM   #3
motex
motex's Avatar
Costa Rica
523
Paid the equivalent of U.S. $110, Amazon CTEK (56-959) MUS 4.3 TEST&CHARGE 12V Battery Charger $95
      07-15-2014, 10:20 PM   #4
doug_999
doug_999's Avatar
2542
Drives: 2011 1M/2021 992/2023 X3
This is a CTEK charger and you can find them on Amazon (for those of you with access to this).
Look up CTEK 4.3 and you will see the various models avail. The 3300 is also a good one but does not have the recondition mode (which is ok, but not a long term solution)
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      07-15-2014, 11:32 PM   #5
motex
motex's Avatar
Costa Rica
523
Totally right, here the link to Amazon
http://www.amazon.com/CTEK-56-959-CH...attery+charger
      07-16-2014, 08:02 PM   #6
barcelona
barcelona's Avatar
Drives: X
Thanks for posting as I wanted to mention that this model is now available in the US.
I bought the 82-11-2-296-579 BMW Power Tender plus ( older type charger), but it only shows what stage the battery is charging, i.e Bulk & absorption, absorption or fully charged.
This (new/er) model seems to display much more. Charger is cheap compared to cost of replacement battery. One time I drove away with the connections in place, I thought that when the wires separated that they were severed. I was happy to see that that was not the case as there is a quick disconnect whereby they simply became unplugged.
      07-17-2014, 08:07 AM   #7
JVX6M
JVX6M's Avatar
Drives: 2023 BMW M3 Comp
Why does the error only occur in the winter months. My X5M is a daily driver and does not sit anything more than overnight hours. Is it just the temp that can drop it just enough to create an error? It has not happened since January, February...
      07-17-2014, 07:34 PM   #8
motex
motex's Avatar
Costa Rica
523
I ended ordering the CTEK (56-959) MUS 4.3 TEST&CHARGE 12V Battery Charger from Amazon because for my bad luck, the one I bought locally was an European version only so it only runs in 220-240V, here is Costa Rica we use 110-120V as in the US
The problem with my car is that only runs about 15 miles per day average (5000 per year) and in work days,it seats in my office from 9am till 6pm... I hope this charger will stop the warning message, will keep you posted after I start using it, hopefully will get it by this Monday
