01-20-2016, 05:22 PM | #1 |
Rep 1
rear self leveling suspension
Can anyone out there help me to determine if I have an issue with my 2008 BMW X5 rear suspension? After parking outdoors all day in cold weather (~30F) I noticed that the rear of my car was sitting noticeably lower than my front. I unlocked my car using my remote and this seemed to activate something that sounded like a pump. I walked around my car and noticed the rear of the car was rising back into it's proper position. I drove my car home without any issues. Additionally there were and are no warning lights or error messages on my dash or in my history. Is this a signal that there is an issue with the self leveling suspension? I never noticed this before. As a side note, my third row seating was engaged at the time. I have since disengaged it and returned it to it's stowed position.
02-03-2016, 03:45 AM | #4 |
Rep 11
I'm having the same issue and suspected airbag was the culprit. Anyone have experience with the cost of replacing and should both rear be done or just the faulty one? I think the prices are under $300 for each bag if I'm not mistaken. Labor though......
02-05-2016, 01:09 PM | #6 | |
Rep 1,340
Here's a DIY if you're interested (based on this, the labor should be no more than 1 hr per side): http://www.bimmerfest.com/forums/sho...ghlight=arnott |
02-05-2016, 01:10 PM | #7 |
Rep 1,340
02-06-2016, 06:31 AM | #9 |
Rep 1,491
Hello fellas!
I just replaced my two rear bags with Arnott ones and they ride great. $1800, $2500, or little less is just highway robbery from the Indy or Dealership. I did mine in 30 min each side, I got the bags locally and saved a ton of money. Yes, you can find them online for $160 to $200. By both and do it yourself. This is DIY job, Arnott even has a 7 min video on how to do it. I hope this helps if you have any questions PM me and you can give me a call. |
02-06-2016, 02:17 PM | #11 | |
Rep 1,340
02-06-2016, 06:08 PM | #12 | ||
Rep 1,491
Another suggestion, shop around get the parts and then get an indy to do the install. Well if you decide to DIY, hit me up and I can help you out. Good luck! |
02-06-2016, 08:37 PM | #13 |
Rep 600
Unfortunately that is what BMW counts on ... and then they rob you.
PAX5
BMWCCA 20645 |
02-14-2016, 11:59 AM | #15 |
Rep 3,647
02-14-2016, 02:22 PM | #16 |
Rep 51
I have the air suspension in my 4.8i w/o 3rd row, i got one of them replaced under cpo but the otherside went 2 months later, 1 month after warranty expired. I replaced this one myself and it only took approx 30 mins. Most of that time was trying to figure out how to take it off.
Both were replaced with oem bags from the dealership, the one i had to purchase was $300 CAD discounted. If i were to replace them again i would go with the arnott brand as they use continnental rubber. I trust continnental as i use the Extremecontact DWS tires and use their V belt for the serpentine belt Driving with a blown bag is the scariest thing... soo bouncy i thought my rear end was gunna come off the ground with every little crack or hole i drove over |
02-14-2016, 02:34 PM | #17 |
Rep 38
So they are not like Benz or LS and 1000 a piece. They only put em in the thrid row as they expect more weight to be in there for the self leveling headlights? Does it make the ride that much different than without? Have a LS430 bags 4k for new airstruts no arnott copies. thanks
02-14-2016, 10:48 PM | #19 | |
Rep 51
I think the main reason for the air bags was for towing and heavy capacity loads to keep the truck level. The older e53 v8 x5s had airstruts in the front and back and were around 1200CAD a piece |
02-29-2016, 09:59 AM | #20 |
Rep 11
I ordered the Arnott bags for the rear and called the Indy shop for an appointment. SA indicated that it might not be the bag, perhaps an air line is blocked, they have seen this a few times apparently.
I'm hoping for the best but preparing for the worst. Will post as more info is available. UPDATE..... Got her back, it was the right spring. Both changed $500.00 bucks for labor at the Indy shop, good as new. Thanks fellas!!!! |
02-29-2016, 10:16 AM | #21 |
Rep 11,891
On the DIY, how do you rotate the bad 90 degrees? Doesn't the weight of the car sit on it? Or is it after you have the car on jack, no weight is on that part of the suspension?
03-07-2016, 04:19 PM | #22 |
Rep 51
Jack it up first and pop the bottom of the airbag out, its a clip and then twist the top. As long as the wheel is in the air then theres no weight on it. Just make sure when u put the new one in that the bag isnt crinkled or it'll wear and leak prematurely
MODS: K&N drop-in air filters, USMILLWORKS adjustable plate mount, aerodynamic kit, vinyl wrapped gloss black interior trim, one off custom rear trunk spoiler, tinted tails, magnaflow free flow mufflers, H&R 1.2" Lowering springs with adjustable links +many more
