      06-19-2021, 07:05 PM   #1
colandreo
Drives: X5, 32ci, 528, 750il
Total System Failure...
Hi Everyone. Any help on this would be greatly appreciated.
My wife parked her 2012 (e70) X5 in the garage last night. Everything was fine.
She went use use it today and upon pushing the button, it is telling her that basically every system has failed. For example, the vehicle will not start (does not crank over)...and it is indicating an auto leveling failure...a transmission failure...an xDrive failure...a parking brake failure...an ABS failure...basically everything.
I removed the negative battery cable to try to clear errant codes and it did nothing. I tried to pull codes with my scanner and it cannot connect. And I grounded the engine block to the negative jump lug under the hood just in case the engine ground strap failed. And all of this did nothing.
Any ideas?
      06-19-2021, 07:27 PM   #2
zoom750
Drives: 2013 X5M
Did you check the Battery? Could be failing.
      06-20-2021, 06:55 AM   #3
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
2nd that. Yup sounds like a bad battery.
      06-20-2021, 06:27 PM   #4
JMAN1111
Drives: F86 Black Fire X6M, F16 X6 50i
Main battery give it a nice charge from the terminals
      06-21-2021, 07:58 AM   #5
ryansbmw
Drives: 2013 X5 35i M-Sport, 2010 535x
My 1st thought was ground strap. I had the exact same issues. Since you said you had a workaround for that, I would guess battery
VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
Need coding or modules reset? PM me
      06-22-2021, 05:40 PM   #6
titanle
titanle's Avatar
Drives: 2010 X6 Activehybrid
Check the battery. Mine got all sorts of errors and it was the battery that was failing.
