      06-14-2014, 10:06 AM   #1
094.8x5
Drives: black on black on black
Aircondition Malfunction
This is a bizzare one,,all controls are set same,,,the passenger side blows 10 degrees warmer,,thoughts ? Thanks
      06-14-2014, 10:42 AM   #2
300hp
Drives: X5 & 335xi
Is driver side ventilation set the same as passenger side in the Idrive menu? This makes a HUGE difference especially if one is dialed all the way to the top and the other all the way to the bottom
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs
Deep Sea Blue Metallic 2013 X5 35d Sport
Prem, Convenience, Cold and Premium Sound packages
      06-14-2014, 12:04 PM   #3
094.8x5
Yes,,front sides are set same , as well as rear,,basically front to bck passenger side is different
      06-14-2014, 09:27 PM   #4
Thirdy
Drives: F48 Estroril Blue M-Sport
low on freon
      06-15-2014, 08:21 AM   #5
CarFan
Drives: 2013 X5 3.5 Premium
Are you sure you have checked the underlying ventilation settings? The digital dial and the ventilation setting are not one and the same. The reason I ask is that you said "as well as the rear" yet there is no ventilation setting for the rear only the digital dials. Before taking it in for service check the ventilation dial which is set using the nav wheel for left and right.
      06-15-2014, 09:04 AM   #6
300hp
Drives: X5 & 335xi
+1
This setting is found under climate controls in the Idrive menu
      06-15-2014, 09:36 AM   #7
300hp
Drives: X5 & 335xi
FYI
      06-15-2014, 10:10 AM   #8
joe_planet
Drives: 2011 X5d
Sounds like a sensor problem
      06-18-2014, 09:13 AM   #9
jmshevik
jmshevik's Avatar
Drives: 2011 X5 50i Dinan
had same prob. I was low on freon. I charged it up to the prescribed amount on the can and all is good now.
X5 50i Dinan Stage 4, Exhaust, Intercoolers/AR Design Downpipes
      06-18-2014, 03:39 PM   #10
094.8x5
You are correct,,just got back from the dealer,,,low freon. I was told that the only reason that the drivers side was blowing colder is that its by design,,when the system detects that its low it all goes to the driver side,,,because thats whose most important at that time,,,, ;-)
      06-18-2014, 06:22 PM   #11
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Did they check for leaks to fix the underlying problem? In theory you should not need freon or R134 whatever they use now.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      06-30-2014, 06:52 PM   #12
094.8x5
It was the evaporator behind the dash with a leak.....over a 1k,,,covered by CPO warrenty
