      06-27-2014, 11:58 PM   #1
moeenulhaq
Drives: 2011 X5
Wider block look with RFT's
Would i be ok if i replace my rear tires 315/35/20 bridgestone RFTs with a wider tire 325/35/20 non RFT DWS? Hate to loose the block look that i currently get with Bridgestone RFTS…. so i figure if i go slightly wider 325/35/20 instead of 315/35/20 it may make up for some difference?
Any thoughts?
      06-28-2014, 10:29 AM   #2
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Part of what gives the Bridgestone tires the block look is the stiff sidewall. Looks awesome, but you will lose that if you go with non-RFT tires. Going for a wider tire will make you lose the block look even more.
      06-28-2014, 10:33 AM   #3
P1
P1's Avatar
11572
You can see here that the aggressive block-look is gone even with 315 tires. Imagine what it would look like with 325s on the same wheel. The less aggressive thread of the Bridgestones also add to the look. You will have to make the decision between looks and comfort.
      06-28-2014, 08:23 PM   #4
Draper
Draper's Avatar
3461
Drives: M4 Comp / Macan Turbo
It should also be noted that it is a VERY bad idea to arbitrarily upsize or downsize tires in a staggered setup.
Case in point.
http://www.xbimmers.com/forums/showthread.php?t=1001253
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic
      06-28-2014, 09:41 PM   #5
moeenulhaq
Drives: 2011 X5
Thanks, i would prefer comfort over looks. DWS make more sense.
      06-28-2014, 09:44 PM   #6
moeenulhaq
Drives: 2011 X5
Case in point.
Thanks, this is very helpful… ill stick with DWS with oem size.
