      02-25-2024, 07:35 AM   #1
ChristyMcL
Drives: 2011 e70 X5 40d
2011 e70 X5 not starting 4B90 Rail pressure monitoring on start up
My 2011 X5 40d n57 engine cut out while driving and now won't start.
Codes are :
004B90 Rail pressure monitoring on engine start
004610 Rail pressure plausibility pressure controlled
004570 Rail pressure plausibility delivery controlled
I have tested the fuel pre supply system and it is showing the correct pressure.
But when I test the fuel rail pressure while cranking the pressure is way to low to start at 10.4 bar .
Is there any way I can narrow it down further without just replacing the High pressure fuel pump or the fuel rail sensors or what is it likely to be ?
      02-25-2024, 08:57 AM   #2
wcs531
Drives: E90 335xi / E70 X5d
The CP4 pumps in the n57 are known to self destruct and send metal fragments into the fuel system, including the return line back to the fuel tank.
I do not know the best method to check this but I would search the F15 x5 forums since we did not get the n57 in E70s in the states
