      02-15-2024, 06:17 AM   #1
Cnoro
Cnoro's Avatar
Albania
14
Drives: Bmw e70 4.0d xdrive
fog light on and parking light on, is possible?
Hi guy
do anybody tell me if possible have the foglights on and parking lights on ate the same time ( e70 lci)?
any coding or any other ideas
thnx
      02-15-2024, 03:23 PM   #2
Daytonawim
Drives: X5 E70 LCI 3.5i 2012
I could be possible with Bimmercode, the option is there.
But not always you can program every option in the list ii noticed.
      02-16-2024, 02:10 AM   #3
Cnoro
Cnoro's Avatar
Albania
14
i tried a cracked version of bimmercode (month ago) but didn't work , maybe a should try a paid version of bimmercode
      02-17-2024, 11:42 AM   #4
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
I assume you're wanting to have the daytime running lights (DRLs/Angel Eyes/Halos) active with fog lights? So your light switch would be in the "off" position and you want to be able to turn the fog lights on simultaneously?
Here are the options I see in NCSDummy.
DRL_TFL_MIT_NSW - Daytime running lights with front fog lights
PWM_NSW_FKT_TFL - Pulse-width modulation(PWM) control of front fog lights as DRLs
PWM_NSW_FKT_PARKL - Pulse-width modulation control of front fog lights as parking lights
PARKL_FKT_MIT_NSW - Parking lights with front fog lights
SL_FKT_MIT_NSW - Standing lights with front fog lights
The PWM options are probably what you're looking for, or some combination thereof. They only have 1 option and it is set at 0% which means there is no voltage being sent to the lights. You can add values here for the desired voltage but I doubt Bimmercode can do that. You'll need NCSExpert and NCSDummy for that.
      02-19-2024, 04:42 AM   #5
Cnoro
Cnoro's Avatar
Albania
14
thanks,
i will try to install ncs e configure , daytime running lights (DRLs/Angel Eyes/Halos) active with fog lights when my light switch is the off position
