      09-02-2015, 01:13 PM   #1
dy63
Drives: F30
4x4 system / DSC Failed & Active Steering Inactive
Hello,
so weirdly i pulled into the shop to get a drink so i turned my car off...went to get a drink came back into my car and fired up as usual and had these errors that popped up so randomly! the 4x4 error with DSC and active steering is inactive!
looking on the net there is so many different things on here to see what it could be
does anyone have any more of a rough idea of what it could be?
These are the errors that popped up when i did a diagnostics. not sure which modules relate to my problems!
DSC Module - Error 6DEC & 6EA5
DME/DDE - Error 4212 & 4222
AFS - Error 613E
VGSG - Error 55C3 & 55D0
LDM / ICM - Error 644C
RFK - Error A811 & A817
Thanks
      09-03-2015, 04:49 AM   #2
UnicornM
UnicornM's Avatar
Drives: M
Strange. I've had that happen if I've disconnected the battery for a while, usually goes once you do hard left and hard right on the steering wheel or when you get going again.
Clear the codes and check them again.
      09-03-2015, 07:02 AM   #3
dy63
Drives: F30
ive cleared them with INPA but they don't go off the idrive or dashboard.
I will try the hard right and left turn but I doubt the steering needs calibrating it could be a genuine DSC error or something else
      03-26-2019, 03:58 PM   #4
Gabythg
Drives: Bmw e91
2007 Bmw e91  [0.00]
what was the problem? i have the same issue
      04-18-2019, 04:46 PM   #5
yco
i'm just saying
yco's Avatar
5749
Drives: E71 X6M '10 (sold)
better start checking from ABS sensors.. probably the reason of the fault.. but there should be good news too.. when xDrive fails it only sends power to the rear wheels.. can be fun..
      04-19-2019, 07:35 AM   #6
mirob
mirob's Avatar
Drives: M3CX
99.9% it's battery related...weak battery, weak alternator not charging, or bad IBS cable...
      04-23-2019, 05:00 PM   #7
Bilbofraggins
Bilbofraggins's Avatar
Drives: 2013 X6M, 2019 X3 M40I
I'd agree with this....
