      06-08-2021, 11:46 PM   #1
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
Consensus of S63 + BMW Twin Power 10w-60 Oil?
My X6M is going thru oil like a mofo. Is the Shell Helix Ultra-based 10w-60 oil gonna blow out the valve stem seals?
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      06-15-2021, 11:50 AM   #2
1er_vert
Hot Weather ONLY....
The 10w-60 is fine in extreme ambient temps only(110F+).
      06-21-2021, 06:58 AM   #3
Thecastle
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
I would never use an oil of that weight in an engine designed for 5-30. It’s too likely to not flow well into tight bearing clearances and starve them for oil, boom blown bearings.
Fix your oil consumption problem, don’t try to fix it with out of spec oil which will damage your engine in other ways. Or use at-205 to try and revive those seals.
      06-21-2021, 11:20 AM   #4
1er_vert
I tried the AT-205 seal conditioner. It barely even works. I found the Liqui Moly Oil Smoke Stop(LM-2122) works great. Only problem is the product is ONLY available in Europe.
