04-21-2015, 09:19 AM | #1 |
Rep 156
Air conditioning Noise
Hi everyone,
I have been noticing this for the past couple of weeks The noise is like a spinning fan noise coming from the air con. The stronger the air conditioning the louder the noise and it gets quite annoying. Has anyone encountered this? I was thinking, is there a way to clean the fan? or put some sort of lubricant to lessen the spinning noise? |
04-21-2015, 09:52 AM | #2 |
Rep 1,291
It is probably the blower motor bearing. I had mine replaced on my E70 when i had it.
_____________________________________ 2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4 |
04-22-2015, 12:50 AM | #3 |
Rep 156
05-06-2015, 09:23 PM | #4 |
Rep 148
Mine has been making a similar noise more of a whining noise I am taking to the dealer ASAP and will let you know.
Likewise if you taken first let me know so annoying that I typically turn up my music 2011 X6M |
03-23-2016, 02:47 AM | #5 |
Rep 53
This noise should not be ignored. Ignoring allows the problem to get worsen. To work fan properly it is needed to be kept clean and to be properly maintained. If you follow below mentioned steps it will help in removing the sound:-
- In AC debris is to be removed around blades. - If the problem is not debris then the cause is loose blades also. It will be better to tight it. - Check that fan blades are straight. - Lubricate the motor in case of humming or grinding noise. - Noise is due to loose screw also. Mounting screws that are holding the unit in place can also be loosened as the unit operates. Both situation will produce rattling sounds. This can be tight with screw driver. - It may also be due to coil fins clogged with dirt. This dirt is to be removed with vacuum cleaner. |
03-23-2016, 03:39 PM | #6 |
Rep 148
Mine ended up being the condenser...apparently really common on our vehicles...in fact when i dropped off they were already doing another X. sound is quiet now.
03-24-2016, 12:57 AM | #7 | |
Rep 156
