07-25-2014, 03:30 PM | #1 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
Radiator
I just changed out the radiator on my wife's 08 X5 3.0si. The new one comes without any drain plugs and it does not have a port on the lower passenger side of the radiator. So, you have to purchase part no.11537609944, which retro fits the line from the electric water pump to the oil cooler. Now it's just a direct line and the fork over to the lower portion of the radiator is blocked off.
07-25-2014, 03:46 PM | #2 |
Rep 389
I am confused. Are you asking for help or notifying a DIY fix?
If latter, a topic (with pictures) would be appreciated .. |
07-26-2014, 12:14 PM | #3 |
Rep 6,968
Nope not asking for help. Just giving an FYI to anyone who has to put in a new radiator in their E70 with a 3.0. You will need to purchase an additional coolant host that runs from the electric water pump directly to the oil cooler. Of course you have to take the old one out. The old one branches off and used to feed the lower radiator. The new radiator does not have a lower port. It also does not have any drain plugs what so ever.
So, if you were to do a radiator flush, you'll probably need a brake vacuum, and the from there one would have to disconnect a few hoses and then vac out the coolant from specific vantage points. |
08-25-2017, 09:20 PM | #4 | |
Rep 6,968
